Question about Bushnell ® HOLOsight
I have not used my model 400 sight for about 5 years I put a new set of batteries into it but it will not turn on. I cant get the battery check to come on also. Is there a way to check the insides to see if the lazar still functions?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
I suspect corrosion on the battery contacts.Try cleaning them gently with a q tip and some alcohol.Make sure the batteries are in correctly.
Posted on Apr 05, 2015
3 Suggested Answers
SOURCE: bushnell holo sight
It will test the condition of the batteries. Turn the sight on to its brightest setting and leave it for 2-3 minutes. Then while looking at the red dot, press the battry icon button and hold it in. If the image does nothing, you are good to go. If it starts flashing, then you have less than 20% left in the batteries.
Posted on Jun 17, 2009
SOURCE: bushnell banner lite sight where do you put in new
replace batteries by removing top of on/off switch- battery type is 357 eveready
Posted on Sep 04, 2009
How do I turn off the alarm after replacing the batteries in the smoke alarm?
push the reset button and make sure you have the batteries in correctly or it will still sound
Oct 02, 2017 | Home
I have a 2013 600 ace tundra do not charge battery.. and skidoo just turns off... and the lights dim when i do get her going.. what could it be? she cant stay going
either a flat battery or faulty battery cell or cells. Batteries should always be fully charged using a charger before the seasons use. Also the problem with SkiDoos as they are only used a few months of the year. Do you put the battery on a battery maintainer for the summer months? I do with my boat batteries, 24 hours every month. Batteries don't like being depleted as the plates buckle. Max life on a battery would be about 5 years.
Or it could be a faulty alternator. Charge the battery first.
Mar 16, 2016 | Ski-Doo 2013 Tundra LT 600 ACE
I just want to replace the battery in my kidde smoke combo detectitor!
Most modern detectors have a battery compartment right on the top in plain sight, but a few have the compartment underneath, while still fewer have no battery at all. For smoke alarms, if the unit is more than 10 years old the entire unit must be replaced; for CO, the time limit is usually less (5-7 years). The best way to know is to check the model number. Most units are removed by turning counterclockwise. The info you need to find whom to contact with questions should be underneath.
Feb 16, 2015 | Home
07 Ninja won't start
sitting is the worst thing for a bike. you have a bad battery. if you have to leave the bike for a long time, put it on a battery tender or at least start it up once a week. the gas will go bad in the fuel system and the battery will fail. also, when you get a battery, make sure to get a good one from the dealer, dont get the cheap ones from walmart or autozone. a factory battery will last 2-5 years. you will be lucky to get 1 year from a cheap battery.
Jun 27, 2012 | 1994 kawasaki ZZR 400
Battery life-I put new batteries in and it lasted less than 30 minutes-maybe 20 pics before the camera stated replace batteries. Is there a reset-
If you are using alkaline batteries, you should switch to rechargeable NiMH batteries. I highly recommend the Sanyo Eneloop products. You should be able to get 300 to 400 shots before you need to recharge. Get two sets of four AA Eneloop batteries. Don't mix them. They hold their charge for a year and can be recharged a thousand times.
Jul 13, 2011 | Canon PowerShot SX10 IS Digital Camera
I'm sure this will sound stupid, I just bought a rifle with a Tasco red dot scope on it and have no idea how to activate the scope. Any help would greatly be appreciated. Thanks
No, that doesn't sound stupid. It's always a good idea to get all the information before using firearms and their accessories, and I'm happy to help:
The large knob on top of the scope is the rheostat, which is used to turn on the red dot, and adjust the brightness. It can be adjusted from "1" (dimmest) to "11" (brightest). You'll have to be looking straight down the scope to see the red dot, since it is only visible when you're aiming. If you turn on the scope to the brightest setting, and you look through like you are aiming, and the red dot is still not there (or very dim) then you probably need to replace the battery. It uses a 3 Volt coin-style lithium battery, type 2032. Unscrew the battery compartment on top of the rheostat and put the new battery "+" side up. Then replace the battery cover, and you should be good to go. Turn off the scope when you're done to save the batteries.
Since you bought the rifle with the scope already installed, it's probably already sighted in, or pretty close to being sighted in. Adjusting the windage and elevation on the red dot scope works just like other rifle scopes. The knob on top moves the point of impact up/down, and the knob on the side moves left/right. For this model, each click of adjustment moves the point fo impact by 1/2" at 100 yds, 1/4" at 50 yds, or 1/8" at 25 yds.
Be safe, and have fun!
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
Screen says bat low
Found the manual online and it said to put the batteries in backwards for at least 5 seconds to re-set the thermostat. Amazingly, this worked.
Oct 01, 2009 | Honeywell Programmable Thermostat Heater
Bushnell holo sight
Jan 13, 2009 | Bushnell ® HOLOsight
Minolta dimage 7i
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DONT FORGET TO RATE;
Oct 10, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Bushnell ® HOLOsight Logo
133 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
