Question about Nextar Q4-04 Car GPS Receiver
I've had the system for apprx 8 months, and recently while on a long cros country trip the ETA portion of the system started to malfunction. I can be 40 minutes away from a destination and the ETA will tell me I won't arrive until hours later. I reset the system, placed it on Pacific time and it still continues giving me the wrong ETA.
  • 587 Answers
Sounds like you have it in Bicycle or Pedestrian mode instead of Automobile
go to Tools.... Settings.... System..... Usage Mode .... make sure you have it on Automobile
Posted on Nov 09, 2010
Tip
Water well cleanig
everybody living in the country with a water well, should and can clean their well with peroxide. A safe fashion is to use sodium percarbonate.Depending on the product and strenght, use apprx 4 litres of sodium percarbonate in well, run a garden hose back to well, then make water run for apprx 8 hours at 1/4 flow.Open all fawcets in the home , one at a time for a period of 5 minutes to alllow the well water contact your piping, thus cleaning these.Leave to sit overnight, with garden hoe removed.Reconnect hose in the morning, flush for an hour or so or until you run out of water. Do not let your pump run dry for any extended period of time otherwise you will burn the pump.You know the sodium percarbonate is gone when the water is free and clear of foggy looking airated water
on Nov 11, 2011 | Stainless Dishwashers
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Why Is It That Windows 7 "Help & Support" and The "View help" Tabs No Longer Open?
Something done 8 months ago seems a long time before you noticed that the help function had gone. So could it be more recent?
You could try System Restore. This will put restore your system to an earlier time. You can pick that point. Not certain it would go back 8 months though! Type System Restore in the search of the start menu. When it comes up click it and follow the directions. Shut all programs down before you do (except windows).
Sep 02, 2014 | Computers & Internet
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
"service traction control" light came on
THE MALFUNCTION HAS ALREADY OCCURED, WHEN THIS LIGHT IS ON THE SYSTEM HAS BEEN DISABLED, HAVE THE DEALER TEST THE SYSTEM FOR THE TROUBLE CODE THAT WAS STORED WHEN THE LIGHT CAME ON.
Jun 16, 2009 | 2002 Chevrolet Impala
Leakage when filling espresso cup
I had the same problem, there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round. Replacing it with a seal from the hardware store corrected my problem...GOOD LUCK!
Mar 10, 2008 | Lavazza Espresso Point Capsule Machine
Nextar Q4-04 Car GPS Receiver Logo
78 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
