Question about NetGear Computers & Internet
How do you put a password on the modem so other people cant access it?
The wireless indicator wont light up so i cant go wireless ?
Hi Desmond
This does not appear to be an actual question!
You actually made a statement.
You need to find the IP address for your modem (e.g. 192.168.1.1) Use your Browser to gain access to this address, By typing in the IP adrs into the URL space at the top of the browser window.
Supply the modem password required for your home modem.
Then you have access to change settings to turn on the WiFi section. Change it's channel (1 to 13) and set the wifi password.
Cheers
Setting up Wireless Network with Access Point Dlink and Modem ADSL
How to Configure the Modem Router
How to Setup An Airport Extreme
Sep 14, 2016 | Computers & Internet
Need to access the internet but keeps saying that it cant establish a connection
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
don
Feb 19, 2011 | MetroBook VL Plus C-266 Notebook
Cant login to the internet
also
hope this helps
don
Feb 14, 2011 | Computers & Internet
I forgot my password and cant login again.
hope this helps
Jan 09, 2011 | Computers & Internet
I cant get online with my laptop, says connected but with no internet access and when troubleshooting it tells me that my DNS server isnt responding and im using WIndows 7
ring your ISP internet sevice provider get them to check your modem for internet access you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
hope this helps
Dec 05, 2010 | Computers & Internet
I dont know my wireless password and i need to know how to get it, if possibal
YOU CAN GET YOUR PASSWORD THING IS YOU HAVE TO USE ETHERENET CABLE
and flowo the instuction
1 conaact your modem in your computer thoure your ethere net cable
2 put your IP addres of your modem in Explore
(Example : http://192.168.1.1)
3 after that you will able to weive your modem setup
4 it will ask password of modem put that and u will able to acess you modem from there u will able to fine your wireless password in wirless option
i hope u will able to access your modem
Apr 17, 2010 | Zoom X6 (5590) DSL Modem (55900003)
How do I set password so people cant tapp into my wireless connection
you need to go to the security settings of your wireless access point and set up web key. Steps are below:
Step 1:
Access the access point’s web-based setup page.
Step 2:
Look for Wireless Security.
Step 3:
Look for Security Mode and select WEP.
Step 4:
Look for the WEP Encryption and select.
Put the desired password and remember it.
Nov 26, 2009 | Arris Computers & Internet
Cant access the cinfiguration
In your browser's top window type:
http://192.168.0.1
or try
http://192.168.1.1
If it is new, try :
user: admin
pasword:password or password1 or admin
May 03, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Cant access speedstream modem
Turns out that the modem stopped transmitting a wireless connection so that is why we couldnt get it working. After nearly putting a hammer through the laptops, we decided that we had better buy another modem. It now works better than ever :-) (phew)
Mar 25, 2009 | Efficient Networks SpeedStream 5100 Modem
Unable to connect internet
hi,
theres a possiblity that the modem is set to bridge mode,in that way,you will not be able to connect to the internet direclty to the modem,192.168.1.1 is usually the deault gatewayy address for almost all verizon modem and username is admin and password is admin as well,if admin didnt take for the password,try using password as the password
thanks and God Bless
Dec 10, 2008 | Toshiba WRC 1000 Wireless...
Computers & Internet Logo
122 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
