Question about Samsung HLP5674W 56" Rear Projection HDTV-Ready Television
Ballast replacement I'm finding it very difficult to replace the ballast because the screw is not in a position for me to get a screwdriver there. Are there step by step instructions available?
  • gmoney424 Jun 16, 2008
    Thanks, but how do I remove the light engine. I was able to remove 3 screws from the ballast, but it's the 4th screw in the upper right hand corner that I can't reach. Thanks
  • Samsung Master
  • 8,617 Answers
Its actually easier to remove the light engine in order to get to the ballast easier unless you have a flexible screw driver. i am not aware of any step by step instructions other than possibly the service manual and often those arent very explicit.
Posted on Jun 16, 2008
  • Sonny Berry
    Sonny Berry Jun 16, 2008
    send me an email to my private email and I can send you a file that may help you, its not for your model, but they are all really close to being the same.
    slinteriors@yahoo.com
How do I replace front HID light bulb? and where can I purchase parts for replacing?
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
May 21, 2014 | BMW 335i Cars & Trucks
Tip
How to Replace the Ballast in a Samsung DLP
Fist what is a TV ballast?
A television's ballast is a device connected to the lamp that provides an electric current, keeping the lamp operational. If you have a new lamp that isn't working properly, then you will more than likely need to replace the ballast. Replacing your television's ballast is less challenging than working with other parts of a Samsung Television, and is something that you should be able to do yourself.
  1. Remove the back panel of your Samsung DLP television, and then remove the lamp.
  2. Carefully unscrew the cover sensor switch, which should be located near the bottom-right side.
  3. Remove the two screws holding the lamp connector in place and slide it out.
  4. Remove the screws holding the inside unit of the TV in place, and very carefully ease the right side out, allowing access to the ballast.
  5. Unscrew the circuit board, remove the two cables going to the existing ballast and replace it with the new ballast in the same fashion.
  6. Put the inside unit of the television back in place and screw it in.
  7. Reattach the cover sensor switch.
  8. Reinstall the lamp and screw the back panel of the television back into position.
hope it works..
this is a image of the ballast of a Samsung .
on Mar 25, 2010 | Televison & Video
I have problem with hid light
follow this link to u-tube video not the exact vehicle but the principle will be the same,or search for your exact vehicle
How to replace low beam xenon HID bulbs 2006 BMW 330i
May 08, 2014 | 2007 BMW 335i Coupe
BALLAST FOR PRO 24
A trained technician should: Turn off power to bed. Remove top or bottom cover as necessary, Locate bad ballast, Insert small insulated screwdriver into slot on end of ballast and pull out wire, Remove one screw that holds ballast in place and loosen the other screw, The end of the Ballast should be slotted - so pull it out from loosened screw. Now reverse the process to install new ballast. After remounting ballast to bed, simply push the wires back into small holes in connector.
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
Have checked all connections. Perfect audio. No picture. Have tried different channels. Does Akai have a recommended service depot or parts supplier in the Vancouver, Canada area? I suspect we need a lamp....
The television is actually pretty easy to check if you have a multimeter, T10 torx screwdriver or T10 socket, and a Philips screw driver. First of all remove the back cover from the television, do not worry about the screen assembly, it is flimsy but it is mounted on the inside to not go anywhere when the back cover is removed. Next remove the black voer that is mounted by 4 torx screws, the cover that has the projector part of the engine assembly sticking through, be careful not to damage the black foam rubber that is around the projector head. Once you have those two covers off, unplug the ballast power supply wire which is the white and black wire on the bottom of the ballast, the ballast is the circuit board that is mounted in front of the big fan on the right side Also has two wire coming from the top that plug into the lamp housing. With a multi meter check to see if you have power going into the ballast (TV has to be plugged in and turned on to do this step). If you have power going in then turn the television off and unplug it and and plug the power supply wire back into the ballast. Next remove the lamp which is secured into place with the one screw on the left side. See if you have power coming out. If you have power coming out than replace your lamp. If you do not have power going into the lamp than replace the ballast. If you do not have power going into the Ballast than replace the power supply which is part number DVL-U2830XC good luck in finding that part. If you have power going through to the ballast, and to the lamp and have replaced the lamp than replace the video board Part Number B0001
Dec 19, 2010 | Akai PT46DL10 46" HDTV-Ready Television
The lights indicated that I needed to replace my lamp. After doing so, the TV still doesn't have picture. What do I have to do to get it to work?
It is possible that the Ballast is not turning on the lamp. In past years it had been difficult to get the Ballast separate from the Optical Block but they seemed have them available. In order to replace it you will need to remove the Optical Block which is in the center. The ballast assembly is mounted on the right side of the OpticaL Block. Once the Optical Block assembly is removed, it is not difficult to replace. To order a Ballast, call 1800-631-3811. You will need the model number.
I hope this helps,
Skyassoc
Dec 10, 2010 | Toshiba 62HM95 62" DLP HDTV
How do you change front headlight blub 2008 sonata
how do you change front headlight blub 2008 sonata
Nov 28, 2009 | 2008 Hyundai Sonata
Won't show picture but has sound
You can have numerous problems. I have the exact same television in my shop awaiting parts because they are extremely hard to find. The service manual is useless unless you have the diagnositc software adn operational software to properly test the television, so do not attempt to buy a manual online you will waste your money. The television is actually pretty easy to check if you have a multimeter, T10 torx screwdriver or T10 socket, and a philips screw driver. First of all remove the back cover from the television, do not worry about the screen assembly, it is flimsy but it is mounted on the inside to not go anywhere when the back cover is removed. Next remove the black voer that is mounted by 4 torx screws, the cover that has the projector part of the engine assembly sticking through, be careful not to damage the black foam rubber that is around the projector head. Once you have those two covers off, unplug the ballast power supply wire which is the white and black wire on the bottom of the ballast, the ballast is the cicuit board that is mounted in front of the big fan on the right side Also has two wire coming from the top that plug into the lamp housing. With a multi meter check to see if you have power going into the ballast (TV has to be plugged in and turned on to do this step). If you have power going in then turn the television off and unplug it and and plug the power supply wire back into the ballast. Next remove the lamp which is secured into place with the one screw on the left side. See if you have power coming out. If you have power coming out than replace your lamp. If you do not have power going inot the lamp than replace the ballast. If you do not have power going into the Ballast than replace the power supply which is part number DVL-U2830XC good luck in finding that part. If you have power going through to the ballast, and to the lamp and have replaced the lamp than replace the video board Part Number B0001, good luck finding that part. If you have replaced the Video board, ballast, lamp, and power supply and it still fails part your television out and make parts available for other people because the last thing is the engine assembly which costs 2999.00, yes that number is right Two Thousand Nine Hundred and Ninety Nine Dollars. Again, parts are very hard to come by for that model and unless your a customer like that one I have that actually wants it fixed don't bother with it.
Feb 24, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Replacing ballast board
ballast board is difficult to obtain better ask good service center for help.
Jun 28, 2008 | Office Equipment & Supplies
Samsung HLP5674W 56" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Henry  Thomas
Henry Thomas
