Question about Sony Playstation 3 (PS3) Console
I was playing a game on the ps3 and the system just shut down. i tried to turn it back on but the red light flashes making a beeping sound
  • 87 Answers
Try holding the power down till you hear several beeps. Takes about 8 seconds.
-david
Posted on Nov 09, 2010
5 Suggested Answers
  • 38 Answers
SOURCE: playstation 3 shuts down as game loads
Generally there are a couple of things that can cause this. Bad installs of games, and more commonly thermal damage. The bad news is it will probably have to be repaired and Sony generally charges about $150 for that. Hopefully its under warranty? =)
There is some talk that the new firmware download may have altered physical parts that control the temperature inside the unit. Although that's just heresay i've been hearing more and more people thinking this is the case.
Posted on Mar 05, 2009
Phantomgreen
  • 128 Answers
SOURCE: system shut down while playing game... light
This is known as the yellow light of death.Similar to xbox 360 ring of death,this is normally caused from overheating from the console.If it is still under warranty contact playstation and send it back to them other wise it's about $150.00 usd to have it repaired. Here's the number
1-888-
780-7690 between 6AM - 8PM (PST) Monday - Saturday and 7AM - 6:30PM (PST
Posted on Apr 14, 2010
  • 387 Answers
SOURCE: My PS3 (40Gb) has just shut down on me. I was
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Posted on Feb 25, 2011
  • 34 Answers
SOURCE: About 20minutes ago my ps3
Hi speeed_race,
The PS3 red light is a huge problem and it is caused by the GPU and the CPU overheating, all you need to do is stop the heat build up.
You have 2 ways of doing this:
You can send it in however bear in mind that for the fix you will have to wait for 4 weeks and also pay out $150 as well.
Or you can use a good PS3 Repair guide to fix the problem.
Make sure you check out these reviews of the top PS3 Repair guides first!
Cheers!
Posted on Apr 04, 2011
Fully backwards compatible ps3 shuts down with 3 beeps and flashing red light when trying to play ps1 games
Hmmmnnn, consider the reason they pulled the rev compatible system off the market. It is possible to be getting the symptoms of YLOD without it actually happening with some games. The older games spun faster(sometimes) and made the system work harder. It could be heating up and shutting down right at the point of failure. I've seen 2 different revers compatible systems YLOD the same way. Good luck.
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
Playing a game,then it just shut down,now it wont switch back on and the red light is flashing.
Ok this should problebly work if the ps3 is on but the red light is on(NOT GREEN) hold your finger on the on button untill is turns red again do the same but this time there will be a beeping sound and a nother one but the 2 one will make 2 sounds nou take your finger of a screen will apear say restore system about 2 times and that should work but plzzz rate me........
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
Hi, my ps3 shutting down when I turne on the power
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 27, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Downloaded update, next day I got the blinking red light
Mate if you turn your PS3 off when the hard drive is still operating or the power shuts of while playing a game and the PS3 is collecting or writing data to your hard drive, it will most definitely corrupt or even destroy your hard drive it is very common in PC's to.
Hint:
1. Do not shut down your PS3 while it is saving a game or collecting info from the hard drive. Rather quit the game then press your off key with one quick touch and let go of it, it will shut down when it is ready or hold down on the remote's PS button and select switch off system on screen.
2. If you live in a area where the power shuts off for no reason please please get your self a computer UPS(UN-INTERRUPTED POWER SUPPLY).
3. If you replace the hard drive make sure you buy a good quality hard drive like a Western Digital or Seagate.
Sep 06, 2009 | Sony Playstation 3 (PS3) Console
PS3 shut down during mid-game/now it will not eject the game disk
not a solution but a possible answer it is possibly the ylod (yellow light of death) it seems a few people are getting this and my ps3 has broke aswell even sony dont know what is wrong with it. but your problem sounds like the ylod
Jun 07, 2009 | Sony Playstation 3 (PS3) Console
PS3 shuts off right as its turned on
Hi, this is heat related and, this issue may have damaged your power supply board. if the red lights continue to flash after you have unplugged this unit for 5 minutes, this will confirm power board failure and, you will need to replace this circuit board.
You can purchase a replacement power supply unit at this link below and i also advise to purchase a cooling adapter for your system as well. this will prevent this form happening again in the future.
CLICK HERE TO PURCHASE A NEW POWER SUPPLY FOR YOUR PS3.
CLICK HERE TO PURCHASE YOUR MEGA POWER MINI COOLING SYSTEM FOR YOUR PS3
May 23, 2009 | Sony PlayStation 3 40GB System
My PS3 wont started up
Hey did you try a hard reset?
Shut the system off then turn it on.
You should now have the red light on the ps3.
Hold the power on and it will kick green beep then go back to red.
Then try to push power again.
If not it may be the heat transfer compound in the system which is wearing away causing it to over heat and shut down as a safety percaution.
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
