Question about Behringer Eurolive B212A Speaker
I blew my behringer b212a speaker, how do I fix it?
videotransmi
  • 105 Answers
SOURCE: i recently bought a pair of b212A behringer
Clipping occurs when an amplifier is pushed to create a signal with more power than its power supply can produce. The red light flashing is warning you that your are overdriving the amplifier located in your speaker cabinets. This can cause damage to your amplifier and or your speakers. You should not allow the volume level to exceed clipping.
For more information on clipping CLICK HERE
Take Care!
Posted on Nov 14, 2009
Testimonial: "thanks! is there anything i can do to improve this problem? such as new cables, better plugs, etc..?"
  • 140 Answers
SOURCE: solution for repair eletric solving behringer b212a
Can not give solution untill units are inspected. Call Pro Line Music 215-736-8055
Posted on Jan 15, 2010
technical114
  • 1851 Answers
SOURCE: after purchasing a pair of behringer b212a
The clip led flashes when a peak value reached the amplifier and it is no way combined with cables or jacks quality (by the condition that all the connection are not in loosing state). So there is no need to change cables or jacks if their contacts are OK. Maybe the signal you are hearing from one speaker has more peaks so the peak led flashes. Here are some tests you can try:
Change the channels. Use the monitor A in the place you were using monitor B and vice versa. Did the peak led flashes at the same monitor?
Change the signal input, if it's possible use a mono recording or enable the mono switch at the mixer, so that make sure that both of the monitors are driven by the same signal.
Reply with the results at this post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 27, 2010
  • 5603 Answers
SOURCE: the sound keeps dropping out of behringer b212a
Make sure your mixer AND these speaakers are ALL powered from the same power source.receptacle for system safety and avoiding ground loops and damage.
Also you should be using balanced lines from your mixer to these.
Posted on May 25, 2010
  • 5603 Answers
SOURCE: The 1/4
I have seen some of the 1/4 inch jacks that had the mounting nut overtightened and it resulted in the riveting of the threaded part to the metal where the wires connect being stretched to the point the riveting came loose, breaking the contact.
The only way to know is to open the unit. Some of the board mounted "plastic" wonder jacks one can't even see without unsoldering them from the circuit boards.
When replacing do NOT overtighten the mounting nut !!!
Posted on Jun 18, 2010
Where can I dowload the user manual
Here is the link to that manual.
http://www.behringer.com/EN/Products/B212D.aspx
Jan 02, 2015 | Behringer Eurolive B212A Speaker
Diaphragm replacement parts
Hi
Here's the list of authorized Behringer dealers which should be able to help you out.
-Steve
Find Service Center
Nov 14, 2013 | Behringer Eurolive B212A Speaker
Behringer Fuse Holder for B212A
I realize this is an old question, but if anyone else has the same query, from page 6 of the manual listed below, the fuse holder is located on the back panel between the power on switch and power socket. For use on 120v supply, 5 amp/250v. For use on 240v, 2.5 amp/250v.
-Steve
http://www.behringer.com/assets/B212A_P0261_M_EN.pdf
Oct 24, 2013 | Behringer Eurolive B212A Speaker
Behringer monitor lost treble
First and formost check the connections and ensure no stray strands between cables are touching, also the surface of the speaker is not been damaged
Jan 22, 2013 | Behringer Eurolive B212A Speaker
The sound keeps dropping out of behringer b212a speakers, I am not running them hard. could it be the mixer?
Apr 12, 2010 | Behringer Eurolive B212A Speaker
Solution for repair eletric solving behringer b212a
Jan 15, 2010 | Behringer Eurolive B212A Speaker
Blown horn
Remove blown horn speaker and take it to a electronic shop and asked them to check with special speaker meter to see the condition of speaker widings.
Jul 26, 2009 | Behringer Eurolive B212A Speaker
... B212A question
If the B212A does not have the outputs to connect an array of passive speakers, then the answer is no.
Jun 19, 2009 | Behringer Eurolive B212A Speaker
Output volumn low on behringer B212a
Hi...
Swap the input signals...Does the problem move to the other speaker?
If not , it will need a tech to troubleshoot it.
Mar 31, 2009 | Behringer Eurolive B212A Speaker
Behringer Eurolive B212A Speaker Logo
104 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
