Question about Navigon 2100 Portable GPS Receiver
The volume has slowly gotten lower and lower now i can hardly even hear it. i've checked to make sure that it was still set at max volume. even when you turn it on and the navagon imagery shows up the music that it play you can barely hear it. thanks
  • 587 Answers
Go to Tools...Settings....Volume....check your Master / Nav/Media volume control there
Posted on Nov 09, 2010
NO SOUND FROM MY COMPUTER
Check the Mute button make sure it is not selected, also check the volume level,move the volume setting higher or to max.
Check the audio chip is OK by plugging headphones into the audio out/headphone socket.
If it is OK then most likely the speakers are faulty and they need to be replaced.
Mar 15, 2013 | Computers & Internet
The volume is half as loud as it use to be. How do I fix this?
right click on the volume speaker at the bottom right of your desk top ads press sound or playback device select the sound you are useding.go to properties select levels and turn it up this should help.
Aug 13, 2012 | Insignia Televison & Video
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
Very low sound volume
1. In bottom right of your taskbar is an icon of a small speaker, click on that and make sure the slider bar is at 100%.
2. Click the windows button in lower left corner and then click on control panel. Then click Hardware and Sound, then click adjust system volume and make sure those are at max volume and not muted.
3. Depending on your system there may be software that installed to manage your sound card or onboard sound, if there is usually there will be an icon representing it on the lower right of your taskbar. Open that and make sure sound levels are set to max and not muted as well.
4. Make sure you plugged the speakers into the right jack in the back, sometimes when plugged into the wrong hole you can faintly hear sound but thats it, USUALLY its the light green jack you want but that can vary (some sound card/connections will have small icons by each of the colored jacks as well though they are usually faint and kinda hard to see...they can help make sure speakers are plugged into the right spot)
5. Its possible your speakers are just old or defective and simply need replaced.
Feb 18, 2011 | Computers & Internet
Very Poor Sound level on ASUS VW223T monitor
check to make sure you have the proper drivers for the monitor.
May 18, 2009 | ASUS VW223T 22in 16:10 5ms LCD Monitor...
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Volume low
there is problem with ur speaker which make sound. it need to be replaced take it to technician so it can be replaced
Feb 25, 2008 | Motorola Mobility V360 Cellular Phone
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Navigon 2100 Portable GPS Receiver Logo
122 people viewed this question
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
