It doesn't work
My asrock mother board doesnt turn on i tryied reseting the cmos, jump starting from the board i check the power supply im fresh out of ideas
  • 385 Answers
Try chaning the bios battery to a new one. Then leave it plugged in for a little while and try starting it up. If it still doesn't come on, then it's down to either the motherboard or the processor. If the processor is bad, the motherboard will not power up. Also, check the motherboard to see if there are any signs of swollen capacitors or burnt items on it.
Thanks,
Lolita
Posted on Jun 16, 2008
Wont let me type bios password
SORRY ~ you did NOT include your model number! DANG IT I wish fixya would make that MANDATORY!
Now I must use a VERY broad brush to help!
Have a NEW and FRESH CR2032 Battery ready... because it's a dang shame to finally get access to the battery and not replace it with a new one!
1. Remove your laptop battery and power supply or AC connector.
WARNING!! USE EXTREME CAUTION HERE!
IF YOU Break one of the TINY CMOS battery "retaining clips" and your MOTHER BOARD IS TOAST!
2. OPEN your Toshiba and CAREFULLY REMOVE your CMOS BATTERY... they usually look like a 50 cent piece. One clip (shown to the RIGHT in Photo 1) GENTLY pulls aside... the battery pops out. IF you feel the slightest resistance STOP and try the other clip!
Some CMOS batteries have tiny connectors and sometimes they are soldered in: See Photo 2 ONLY and also note the ACID leak!
Those tabs are spot-welded to the battery... Try your best to AVOID stress at the tab and mother board entry point. With GREAT CARE, the metal TABS on the battery body can be torn from the battery body. SOLDER your replacement battery to what is left of the tabs. This saves PULLING the entire mother board ~ NO FUN!
3. After removing the battery ~ With great care, touch or jumper the + Clip with the - Clip to help discharge any remaining voltages (in electrolytic capacitors).
4. Wait 5 minutes and jump the * and - clips again for a few moments.
5. Now install your FRESH battery and put things back together.
This SHOULD TOTALLY RESET your CMOS including your CMOS PASSWORD. It provides a fresh CMOS battery for your system! Be ready to set the DATE and TIME in your CMOS setup too.
Anthony
Dec 01, 2017 | Toshiba Computers & Internet
I have a K8V-MX motherboard. Recently, when i start the computer i will sometimes get no video, sometimes i will. When it doesn't work the monitor just goes into power save mode. Everytime everything...
that happend to me aswell, coz the asus motherboard are like that.
1st unplug all the cabels from the mother board like, harddrive ID and Cd-room ID, leave just the power supply on and try to start Your computer if it doesnt work take off the cabels of USB or anything else that is connected in the motherboard and try to switch it on, if that doesnt work.
get another graphic card and try with it maybe u have prob with ur graphic card, and if that doesnt work take of the motherboard from ur case and try to switch it on like that coz ASUS MOTHERBOARD are really silly sometimes.
hope that Helps.
Sep 20, 2011 | ASUS K8V-MX Motherboard
No pwer
check conections, did you isolated bolts while you ware inserting mother board? check condensators on mother board if there are some leeks... if this is the case ,,, buy a new mother board? is mother board new?
May 02, 2009 | Asrock K7S41GX Motherboard
Reset A Bios of Asrock mother board
go to the following site
http://www.asrock.com/mb/manual.asp?Model=K7S41GX&s=462
download the user manual(not quick installation guide) and check page no 7 or content 1.3 to get the jumper pins to reset the motherboard.
just short those pins and the cmos settings will be gone.
another simple method is just remove the battery and wait for 5 min and again plugin the battery.
thats it you motherboard is resetted to factory settings.
Apr 21, 2009 | Asrock K7S41GX Motherboard
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
I HAVE A ASROCK P4i65G MOTHERBOARD
Hello d0tc0m:
First make sure you have disconnected everything from the mother board...all cards removed, unplug anything on the board such as external fans and so on.
(what can happen is if something is shorted, your system will not start).
Test it then for a short time, if the same thing, then proceed.
A couple things you may consider.
Test the power supply with another board.
Use another power supply.
What you would be doing is by trial and error and elimination.
thanks, take care.
Sep 02, 2008 | Asrock 845GV (P4I45GV) Motherboard
Intel d845gvsr
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
108
Jul 08, 2008 | Intel D845GVSR Motherboard
It doesn't turn on
Try to reset the CMOS, remove the Battery on your motherboard, its like a silver flat coin, or if you can locate the RESET Jumper, just move the jumper to short. Then try booting-up your system again.
I hope this procedure will help you.
-mrsolution
Jun 11, 2008 | Asrock 775i65G Motherboard
Problem with ASRock P4i45GV
THANHTHHP, memory is very important to start computer.Some cpu's need a minnimum [a pair] 2 memory sticks
Do not plug the power supply ONTO the mother board. Do plug the a/c power cord in back of the power box, turn it on.Does the fan turn on [spin] and u feel air coming out? If fan is on, that is good. If fan is NOT on, that is not too bad because some power supply NEED to connected to the mother board for it to have a path.The power supply can SHOT DOWN if connected wrong or there is a short on or in the mother board. Look to see if ANY piece of metal, one of your screws fell in between metal contacts.,Did u put the computer together yourself? Look to see that the contacts [under the board] are NOT shorting where the screws that hold the mother board down to the chassie body
Apr 25, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
