Question about Teledyne Laars Pool & Spa
Model # SWR12R5GDCOH 40amp - 240V - 3+g wiring - phase 1 - 6.0kw heater I was given this spa Friday (working). At my home and wired on Sunday and everything works except I'm getting no heat. The red heat light on the main unit never comes on, but the light for heater on the control panel does light. When I turn the heater to the on position, the pump does start. If I turn the heat dial way down, the elec draw decreases as if the heater went off. Turning it up puts a load on the elec as if the heater turned on.
    President:
  • Teledyne Laars Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Use a digital or analog multimeter to test the heater. Start with voltage to the element probes inside the control box. They will protrude from the S.S. pipe into the control area. Confirm you have 230VAC line to line and then confirm 115VAC from each post to ground. Any variation of more than 10% from those numbers would suggest you have electrical issues.
If you have acceptable voltage to the element and it still will not heat turn all the power off and disconnect one of the line leads from the element post. Use the lowest ohm scale on the meter to measure resistance across the element. A typical reading is somewhere around 10 - 15 ohms...a very low resistance reading. Anything above 20 indicates problems with the element. What you will likely find is an element with infinite or some other reading WAY higher than even 20 ohms. Replacing an electric heater element in a spa heater is a fairly typical repair.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 09, 2010
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
Please tell me how to wire my vanguard 240v water heater model 6e722
Is the breaker across both phases inside the panel? Turn the breaker on and measure the voltage between the black and red wires. If you read 0 across, but read 120V to ground on both wires you're only getting one phase. In your breaker panel there's a plastic piece going back and forth down the back, which seperates the phases. Make sure the breaker for your water heater is installed with one pole (side) on either side of the divider. Good luck!
Apr 18, 2013 | Heating & Cooling
Dayton electric heater model 3UF94 can you rewire from 3phase 240v to singel phase 240v
You can wire any heater with elements to single phase because all heaters are single phase. It will require a larger feed because your amp draw is going to go up doing away with the third leg. You split the heaters up from 3 phase to 2 legs amp draw is going to go up 30 percent or so.
Feb 06, 2012 | Heating & Cooling
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I have 4 -wire 3 phase 220 vac. which is one leg of 240vac, 2 legs of 120vac, and one ground wire On the Stove terminal block I have from left to right on the terminal block at them rear of stove Black,...
First of all I would assume you don't have three phase. Three phase is defined as 208v, 120/240, 240/480 or straight 480v and is used commercially.
Most likely you have a single phase service coming into your house unless you have an elevator or something that would require 3 phase.
A single phase service consist of 2 - 120v legs = 240v and one neutral, if you put a meter across both 120v legs you'll get around 240v and if you place your meter across one leg and your neutral you'll get 120v (not exact but in the range of 124v) Your range will have usually three connectors, red, black and white. So if you run #6 3c with ground, you will have red, black, white and green (its either green or bare). Connect the colors accordingly. You could even have a range that would work off what they call range cable it's legal in most states, which consist of 2 black wires incased in a bare neutral strand and wraped in usually gray insulation, electrical codes vary state to state county to county. The range should have a manual that would tell you what the rating of the electric stove is, such as 40 or 50 amps. 40amp is commonly #8 wire and 50amp is usually #6. I recommend site unseen in using the #6 wire.
Dec 21, 2010 | LG LRG30855ST Stainless Steel Gas Range
Need instructions on how to install a 750W Fahrenheat heater. Wire size, breaker size, etc.
To know what to tell you you need to know if it is 1 phase or 3 phase and what the voltage is that it will be running on...
Assuming that it is 240v 1 phase current you will need at least a 40 amp 2 pole breaker and #8 wire for a distance of upto about 100 ft. if longer then you need to go up to #6 wire....
7500 watts / 240v equals 31.25 amps... so a thirty to too small and you will need the 40....
Wire sizing needs to go larger as the run gets longer...
heatman101
Dec 13, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
Hello im tryin to wire a dayton model 2yu68 unit heater 208v .30 amp bbreaker with 10 awg 3 wire and simple thermostat and still wont fire up
Are you using this heater for a residential application? 208V is typically only seen in a commercial/residential setting. It would be unusual for a home to be wired in what they call 3 phase which is how a 208 voltage is obtained.
Hope this helps. I would strongly advise that you consult with an electrician as 3 phase voltage is not for the average DIY'r.
Oct 10, 2010 | Dayton D-F79 Electric Space Heater- the...
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
MUH108
4awg is about the size of battery jumper cable. or 240v multi-strend cable. and 48A is big. double 40A brakers.
the heater is 208v 3-phase 34,000BTU
it is call out to use the 240 comercial wiring.
Sep 10, 2008 | QMark MUH-35 Heater
Pool & Spa Logo
90 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
