Question about Samsung LN32C350 32 in. TV
Whenever I turn on the tv or watch a movie there is a thin blue vertical line on the left side of the screen that doesn't go away
The problem which is in vertical section on board it is an repairable the filterization capcitor problem
Posted on Nov 09, 2010
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Jan 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LN32C350 32 in. TV Logo
206 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
