SOURCE: xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1. Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1. Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
SOURCE: I am getting error on xerox c2424 disk failur error what can I do
Most likely you wil have to replace the hard drive
SOURCE: xerox workcenter c2424 displays RAM ERROR
Control Panel Help Button Your system's control panel provides you with information and troubleshooting help. When an error or warning condition occurs, the control panel displays a message informing you of the problem. In many cases, the control panel also displays an animated graphic showing the location of the problem, such as the location of a paper jam. To view information about how to fix the problem, press the control panel's Help button, which is labeled with a "?" symbol. You can press the Help button at any time to get additional information about the message or menu displayed on the control panel. PhaserSMART Technical Support PhaserSMART Technical Support is an automated, Internet-based support system. Use your default web browser to send diagnostic information from your printer to our web site for analysis. PhaserSMART Technical Support examines the information, diagnoses the problem, and proposes a solution. If the problem is not resolved with the solution, PhaserSMART Technical Support assists you in opening a Service Request with Xerox Customer Support. To access PhaserSMART Technical Support: 1. Open your browser and go to www.phaserSMART.com. 2. Enter your system's IP address in the browser window.
3. Follow the instructions on the screen.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
