Question about Kitchen Ranges
Looking for a light and 3 speed fan switch for a rotec range hood model 600 manufactured by robinson industies
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
  • 4102 Answers
SOURCE: Replace Broan Model K260A Range Hood Light Switch Slider Assembly
Hi if the new part has no screw holes or place for clip and it is only push in connector ie you dont need to solder the wires to it then it will just pull out use a small screw driver under the edge and gently pry free you cant damage it anymore than it is anyway can you.
Also on the side of the new switch if their is no groove cut into it for a push on clip to hold it in place then it will just pull out and push the new one in.
Posted on Jan 30, 2008
zeusfaber
  • 247 Answers
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Posted on Apr 05, 2008
SOURCE: Random fan speeds and light levels???
I do guarantee work for Broan & Nutone on the road. The problem with all three of your kitchen fans is the control board which is $110.00 part # R111632 for allure 3. If ever, im in Montreal,qc 1-800-363-0566 = Inventex
Jean-marc
Posted on May 14, 2008
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
Can I get filters for rotec range hood.....???
we have no idea here on FIXYA try the manufacturer .
Feb 06, 2017 | Kitchen Ranges
Fan is not working but makes a humming noise at lower speeds and clanking noise at highest speed. When last working there was the clanking noise when I turned off the fan. Please help.
Then turn it off immediately just to be safe that nothing will be broken, can you see the interior? Is there anything broken or loose that might cause the noize? If yes remove.
If not try to clean it with a little cloth or anything, maybe it is too dusty.
Mar 10, 2016 | Electrolux RH36WC60GS Designer Glass...
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M ยท Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Jan 23, 2016 | Venmar Kitchen Ranges
Medium Fan Speed not working
Switch is probably faulty, or wire / connection to switch. If switch and wiring test ok trace wire from that button back to wherever it goes and look there for fault.
May 12, 2014 | Faber TEND30SS300 Decorative Collection...
Taillights wont work, flashers work and brake lights work
The "Fisher and Paykel Fisher Paykel RH361 36" Wall Mount Range Hood with 3 Speeds and 600 CFM Power" doesn't have tail-lights, but you probably knew that.. ;)
On all vehicles the tail lights are a completely separate wiring than the brake and flashers. Look at the fuses for tail lights rather than brake, turn signals or emergency flashers. The tail lights many times use the same fuse as the dash lights, so look for those fuses too.
The bulbs could be bad, but it's seldom both side would be out at the same time.. also look at the wiring, though this would be difficult to trace on most autos.
Mar 11, 2014 | Fisher and Paykel Fisher Paykel RH361 36"...
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Jun 01, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Kitchen Ranges Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
