Question about Denon CDR-M30 CD Recorder
Should recorder play cds bought from shop
Will not playproper cds cannot get it to record says -no disc does read tenion disc but cannot record on it, as played some tracks I had rec on PC
giving up,. regards Jamie
  • 112 Answers
Yes it should play all cd's - the laser is either dirty or needs replacing assuming it can spin discs ok.
Posted on Jun 24, 2008
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
Cannot play this disc
As long as you are sure about using DVD-R which is the most common then i can only assume it did not finalize the disc.
Sep 02, 2014 | Televison & Video
I have a CD-player that says: '' Disc not finalised''. That happends when I put a burned CD in the cd-player and when I put a original CD in the cd-player. What to do???
It should still be possible to play the CD in spite of the Disc not finalised message.
However, I am not clear where you have recorded the CD. When you say origninal CD, is this the one you bought from the music shop.
Finalise CD applies to only to recordable CDs (CDR or CDRW). If you do not have a manual you can dowload one from this site. Refer page 24.
Aug 03, 2011 | Philips CDR778 2-Disc CD Recorder
Which disc can be used to recrord on ?
According to the user manual, the following DVD media you can record with this unit are:
RECORDING: TYPES OF DISCS YOU CAN USE FOR RECORDING
DVD+R 2.4x, 4x, or 8x ONLY; DVD+RW 2.4x and 4x ONLY.
NOTES:
It is NOT possible to record on CD-R or CD-RW discs.
IMPORTANT: It is NOT possible to record content that is copy-protected. This is usually true for most pre-recorded DVD discs and most pre-recorded VHS tapes.
PLAYBACK: TYPES OF DISCS YOU CAN PLAY
DVD discs - DVD movie discs (DVD-ROM); DVD+R; DVD+RW; DVD-RW (must be recorded using video mode or VM); DVD-R (must be recorded using video mode or VM and must be finalized).
CDs (Audio CDs, CD-R, CD-RW) - Audio CDs contain musical or sound content only. mp3 discs are CDs (CD-R or CD-RW)
that contain mp3 files. This product also plays CDs that contain JPEG files and Multisession CDs.
Video CD (VCD) and Super Video CD (S-VCD) discs - Like DVD video discs, VCDs contain picture and sound content. The difference is the amount of information that can be stored on the disc.
VCDs typically have lower picture and sound quality than DVD discs.
Super Video CDs (S-VCDs) can be used to record up to 70 minutes of digital sound and video, with MPEG-2 standard video and MPEG-1 standard audio-but you must use DVD+R or DVD+RW discs to record on your DVD/VCR not S-VCDs.
Additionally, S-VCD disc compatibility is dependent on which MPEG coding software, disc design software, and disc writer software are used; and the discs themselves.
(The above information is extracted from the user manual for this particular model and is a guide only)
I find it very strange that the user manual does not provide any information about DVD-R recording since this is a DVD recorder. I guess you could try those types of discs in it, otherwise it will playback finalised DVD-R discs recorded/burned in another machine.
I assume you have the original manual for this unit. If not, you may be able to download it free from various sites. (retrevo may have it but they may ask you for email address prior to downloading)
I hope the above information helps a tiny bit with regard to DVD formats for this unit.
Mar 12, 2011 | RCA DRC8295N DVD Recorder/VCR
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
Oct 03, 2008 | Philips HTS-6500/37 System
Bush dvr 3006 recorder
this could be a manufacturer issue. there are some optical device that will not support some cds. could be a program glitch. try updating the driver of the device. just make sure the driver is compatible with the Operating System you are using
Jun 07, 2008 | Computers & Internet
Denon CDR-M30 CD Recorder Logo
164 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
