Question about Dell Dimension 4600 PC Desktop
Modem Hi Andrew Not sure whats going on however when i try to set up a modem the only COM port I get is COM1 its a dell 4600 with standard dell modem hardware. I rebuilt the PC am running XP professional any ideas
  • prayag_78
    prayag_78 May 11, 2010
    need your service tag (dell desktop) also let me know wheather u are using any old lpt port printer or a usb one.
  • clark styx valencia
    clark styx valencia May 11, 2010
    do you have the modem drivers properly installed? are there any bangs on the device manager?
  • 43 Answers
If possible take your cpu or tower or the big rectangular box where its written dell on either sides and connect it to a highspeed internet. there is a diference between bandwith and download speed. i need to know your download speed ie kbps..once i know that i shall be able to give you a solution. but for all these you need to trust me! i trust you but do you???? if you just post me a message on this link. i have worked for dell technical support for 3 years, where i was always exploited or misused. but if tomorrow i need to buy 100 computers for my business my first preference would be dell rather then hp, in terms of cost bcoz dell is the cheapest in quality....
Posted on Jun 30, 2008
Zm400 cannot use com1
Use a null modem serial cable . Match computer com1 serial port settings with printer serial port settings.
Nov 04, 2013 | Zebra ZM400 Direct Thermal-Thermal...
Can't communicate on the COM1 port
Is this a printer you have installed and are trying to print to it? Maybe you don't have the printer configured properly. More than likely you should be using a usb port instead of a com1 port if it is a printer. Open your printer and check the properties.
Modems also use com ports, so check your setup if you are using a modem.
Jun 06, 2012 | IBM ThinkPad A31 Notebook
Hi, Installing Creative DI5655 Internal Card Modem on XP I try using the modem for sending/receiving faxes with WinFax PRO 8.0 When looking for the modem through the Control Panel, the modem is...
Hi Roni,
Let's try doing it the easy way first.
  1. Go to START, SETTINGS, CONTROL-PANEL, SYSTEM, DEVICE MANAGER.
  2. Go to the icon that reads network, expand it by hitting the + symbol.
  3. Locate your modem, right-click the icon and choose UNINSTALL.
  4. Hit the "F5" key. It should redetect the modem and install the drivers again by default. If it doesn't you can check the top menu inside the Device Manger for "Scan for new hardware". If you can't find it, just reboot the computer and Windows will detect the modem and reinstall the driver.
It should move the Com back to 1 or 2.
Let me know if it doesn't.
-- Rescue Tech
Dec 11, 2010 | Creative Labs Digicom DI5655 Modem
Can't set up dial-up connection
Restart the computer.
Enter BIOS setup.
Click to "disable" both the COM1 and COM2 (or Serial1 and Serial 2) ports.
Save-and-exit from BIOS setup.
Restart Windows.
The modem should now be assigned as 'COM1', and should work.
Apr 17, 2010 | Arris SM56 (SM-56-PCI) Modem
I have inserted a dial up modem in com1 (only 1 available) windows cant find plug n play device. can i use the ethernet plug to axcess dial up? also only in built speaker work not plug in ones. thanks
Did you make sure the Com1 port was enabled in the BIOS?
And no, you can't use an ethernet card for dial-up.
As for the speakers...double-click the little volume icon on your task bar. Make sure that none of the outputs are muted. That's just my first idea. You may also want to make sure there are no connections off inside the computer going to the speaker jack.
Thanks for using Fixya.
Sep 17, 2009 | Dell OptiPlex GX520 PC Desktop
Can't fax - modems not being detected
ok, a modem on COM8 ? Normally modems are on COM1, COM3. You need to fix that problem first. Most softwares are not setup to scan that high for the modem. (ps: COM2, COM4 are usually for other devices - in the old days, mice were on COM2). Follow instructions:
START
CONTROL PANEL
PHONE/MODEMS
Click over to MODEMS
Click on Proper MODEM
PROPERTIES
ADVANCED
ADVANCED MODEM SETTINGS
Change COM8 port to COM3
click OK, probably going to have to restart computer.
Let's see if this actually solves the issue. if it did not and you need more help, contact me through this site and we will proceed forward.
Jan 15, 2009 | Toshiba Satellite M30-S350 Notebook
Modem
That means that the OS is not seeing the modem. Can you see the modem phone connector. If you do, You may need to reinstall the modem driver.
First, Go to the Control Panel >ssyatem>Hardware > Device Manager.
Go down to ports(COM and LPT)
If Com1 is there , right click and click uninstall.
The go up the page and click on the plus sign . the right click on the modem (if it is there) and click on uninstall.
Then restart your unit.
If this does not work, you need to go to Dell's website and download the modem drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 23, 2008 | Dell Inspiron 1200 Notebook
Pentium III 800 mhz T21 Thinkpad Internet connection problems
why fight it , let it be on com 1 then,
go into the bios and disable the serial ports .
that may be the easiest fix as long as you don't need the serial port for anything.
but if you have a serial mouse oh boy.
May 13, 2008 | IBM ThinkPad T21 Notebook
Modem and port
You will normally need the device driver to install the modem. I suggest find the driver and reinstall it as it is not detected as a supported device by windows.
Thanks J
Jan 30, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Dell Dimension 4600 PC Desktop Logo
29 people viewed this question
Alun Cox
