Question about Samsung Televison & Video
Samsung LN46A630M1FXZA LCD no picture no sound is this expensive to repair
5 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: I have a 46" Samsung LCD, Model #LN46A630M1FXZA.
Remove the ribon cable that is associated with that section where bthe bar is and clean and reinstall that should fix your problem.
Posted on Aug 12, 2011
  • 5 Answers
SOURCE: samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Posted on Dec 31, 2008
  • 105 Answers
SOURCE: JVC LCD Lost Sound
Yes it is repairable
Do you get good audio from the headphone jack?
If yes, then it is the Audio Amp or some component in the Audio Circuit
If NO, then then Audio Switching IC is defective.
Expeens will depend on the person fixing it. expect $70-100 parts. I think labor is normally $80-120. so $150-220 total.
You can get a new 26" for that though. If the headphone works then the Audio Out of the TV will work. I suggest a miini system for audio out.
Posted on May 18, 2009
budmrtn
  • 11361 Answers
SOURCE: our samsung flatscrenn lcd has sound but no
If you get the vertical lines from the top all the way down to the bottom of the screen, it can be two things: the LCD panel is bad (very expensive) or the LCD panel driver board.
Posted on Nov 05, 2009
Can i fix my samsung lcd tv (LN46A630M1FXZA) which was working perfectly then instantly went to a "white-ish" screen where people look they are in a negative appearence.
When you start having issues of a white screen it means Game Over For the screen take it to a professional technician!! Or Look Right here on this site for instruction's on changing out the board if you are a do it your selfer.!!
Jul 31, 2017 | Samsung Televison & Video
I have a Samsung LN46A630M1FXZA TV that had sound but no picture. I changed the T-Con board and now there is a picture but it is very light, washed out.
This is often caused by the Y-sustain board, be careful to drain all power before undoing the ribbons and are all secured before testing with power, I blew my whole board this way.
Oct 26, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
TV clicking on and off with colored screens and noises, not power supply capacitors this time.
Sounds like a main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Samsung LN46A630 46 in. LCD HDTV
Our samsung flatscrenn lcd has sound but no picture just vertical lines through it. why an is it expensive to fix?
Nov 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
32" LCD SAMSUNG 2YRS OLD - PICTURE FOR 5 SECONDS THEN SOUND ONLY
I know it seems like it is a rip off but the diagnoses is probably right. It may well be caused by the digital controller that is mounted to the LCD Panel and is not sold separately so you need to replace the entire Panel whether the Panel it- self is bad or not. Cost of the LCD Panels are expensive and get much more expensive as the size of the screen gets larger. Sorry of the bad news.
Skyassoc
Jun 20, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Apr 20, 2009 | Samsung SyncMaster 720N Monitor
Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
Sounds like your LCD panel has gone bad.
If the unit is under warranty, take it to a Samsung repair shop. If it is not under warranty, go buy a new one. LCD panels are usually more expensive then buying a whole new monitor.
Mar 21, 2008 | Westinghouse L1975NW Monitor
Samsung LE40R51B no picture but turns on
i have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Nov 20, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
88 people viewed this question
Henry  Thomas
Henry Thomas
