Question about Maytag Neptune FAV6800AW Top Load Washer
The UC code appears, and it will not rinse - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
I'm sure you have a Clutch Malfunction.
Is the wash tub banging around as it enters Spin Cycle?
If you empty the wash basket of clothes and do an empty Spin Only Cycle does the Spin OnlyCycle complete?
If so see this post. Clutch Fix
Just in case FIXYA blocks my link paste this into your browser http://www.fixya.com/support/t2070219-model_fav6800aww_will_not_pump_water_out
You can't get the FAV6800A/FAV9800A Service Manual from servicematters.com
You can get it from appliancedigest.com.
Posted on Nov 10, 2010
Samsung washing machine error code uc
Since you are receive UC error code, Please call the after-sales service.
Source: Samsung CS Portal
May 24, 2013 | Washing Machines
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle is not completing, code DC appears.
I have a fav6800 maytag washer, I am getting a UC code. If the drain is blocked in someway will it give this message? the machine works fine till it comes to the rinse and spin and then error code comes...
What are the first to digits of your machines serial number? It will be 10 thru 17.
Did the machine bang around in Spin Cycle during the wash Cycle with the uC error code?
The FAV6800A and it’s sister FAV9800A LCD display version of the machine suffer from a chronic Dry/Rusted One-Way Roller clutch issue. See this Clutch repair post on this forum for clutch maintenance and or replacement and this post on another forum. Read how to check the failure of the One-Way Roller clutches to slip in the CCW/Spin direction at this post.
If you are just a bit handy you can do the maintenance or order a replacement from AZ they have the best price around $56. I will help you every step of the way…..Rich
Couple of links to the Service Manual and Sears Parts Direct for reference.
I’ll paste in how to check the Tub Displacement Sensor. I don’t feel that is the issue but is will give you a chance to go into Service Mode and check thru the lid for proper operation.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine and not the cause of dC or uC unbalance errors……fix the clutch and your machine will be
J
Jan 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG WASHER THAT WAS IN MID CYCLE AND STOPPED AT THE RINSE AND SPIN PART. TURNED OFF THE WASHER AND TURNED ON BUT MAKES A CLICKING NOISE. ALSO LOUD WHEN ITS IN THE SPIN CYCLE. HELP!!!
Sounds like the clutch spring is broken. You should have a UC or DC error code showing on the display. Only fix is to replace the clutch assembly.
Oct 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
UC-21 code and the service manual only goes to UC-20 Model sharp MX-2300
I will have to take a stab at this at this code is not listed in the service manual. The UC codes deal with Counterfeiting! Either the user wanted to try and copy money or they copied something that had the colors very close to money so the only way to fix this is to have an authorized dealer call Sharp and have the boards ordered.
Apr 30, 2009 | Sharp MX-2300N Color Copier
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
Aug 08, 2008 | Maytag Washing Machines
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Replace the clutch.
Mar 10, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune FAV6800AW Top Load Washer Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
