Question about LG Refrigerators
LG Rifrigirator & Freezer Mod.#GS87T65CEF. The smal door that keeps juice etc. is broken. This smal door is to avoid to open the big door saving the engergie "cold' inside the fridge. I would like to order a complete new smal door. (Color is Stain less steel)
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
aborcass
  • 2651 Answers
SOURCE: left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Posted on Nov 28, 2008
DeBruce
  • 145 Answers
SOURCE: stain (drip mark) on front of fridge???
We Use Debruce Polish in all our kitchens, especially cooktops and stainless steel. Debruce also works on polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff is perfect!
Posted on Aug 24, 2009
  • 146 Answers
SOURCE: same problem
If after cleaning your condenser coils at the back or bottom, checking your cold control dial, checking your door gaskets for leaks using the dollar bill technique and looking for some resistence when pulling it out, checking for any obstructions, etc. nothing works, then you will need to have it service - most common problem is defrost timer - If your defrost doesn't cycle on, your evap coils will frost over excessively and you will not get sufficient cooling - you can usually rule this out by turning off your fridge and manually defrosting them with a blowdryer until they are frost free and running your fridge again for a few hours to 24 hours and check the temps again (during this time I'd set the dial to coldest) and monitor regularly, if your temps are getting colder and colder (fridge below 40F and freezer below 0F, then your problem is a faulty defrost timer - or one of its related components. (Remember to set your dial to what it was)
If not - then next common thing is door gaskets and finally a sealed system leak, maybe a tiny one and very slow progressing one,a lthough I would be inclined to think this is not it at this point, but if you get it serviced the first thing they should check is evap fan for proper operation, defrost timer, door seals and then compressor.
I hope this helps.
Why does my frige motor turn on when I close the door and off when I open door?
It's designed that way for energy saving purposes. The motor shuts down when the door is open so that it's not producing more cold air to just fly out the door. Then when the door shuts, the cooling mechanism kicks back on again for business as usual.
Oct 20, 2014 | LG Refrigerators
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
MY ICE MAKER MAKES ICE BUT FREEZES UP AND TRHEN I CAN'T GET ICE OUT. I TRIED TO OPEN UP THE FREEZER COMPARTMENT BUT I CAN'T GET THE COMPARTMENT DOOR OPEN. HOW DO I GET THE ICE MAKER DOOR OPEN. I...
Unplugged, Then allow 1 or up to 5 hour then open, if not get screw to open the compartment door. check all side of the compartment door. avoid so much full content to your ice maker refrigerator, and always give a free space to the compartment door.
May 26, 2011 | LG LFX25971ST Bottom Freezer French Door...
Er dH appears on the fridge screen and its seems that means defrost. The fridge is now not really producing cold and things a smelling damp.
Look in back of freezer and see if rear wall is covered in frost. If yes quickly place goods into a cooler and manual defrost with a hair drier or a large bucket of hot water placed in freezer with power off unplug and shut door. Be Ready for water to spill out on floor because the drain pan may not be big enough to handle all the melted Ice. I will guide you from there but thought to tell you this to save food and money. You will have about 3 days until done again depending on how many times doors are opened. Contact me and I will help you with the manuals and rest here, Thanks Sea Breeze
LG Refrigerator Parts
May 02, 2011 | LG LFD22860 Stainless Steel Bottom Freezer...
I want to a food chart for gym
I am 23 years old. I keep on my gym. I want a well food chart to get fit my body.
Jan 27, 2011 | Weider Nutrition Weider Total Body Works...
When we close the refrigerator door the freezer door pops open. It seems like a vacum problem?
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Dec 24, 2010 | LG Refrigerators
What is the best setting for the freezer and the refrigerator to save electricity?
to save the most electricity.??? turn off // ha ha // to run any frig properly try to keep ref side ( fresh food at 36 to 38 deg and freezer if it has ice maker around 0 to 5 deg . . . to save power . keep the coils clean and door seal clean . make sure doors close properly and seals are good . mm
Sep 23, 2010 | LG LRTC19314ST Top Freezer Refrigerator
I am looking for a refigerator either side by side with no water and ice or a bottom freezer refridgerator needs to be 31 inches wide.
Have you checked out the LG model LFC20760SW French door with no external dispenser, which fits a 30 inch wide opening? (PS. Buy from a small dealer, not a big box or Sears if you want good service over the life of your product) Check where to buy at with your zip code http://www.lge.com/us/appliances/refrigerators/LG-french-3-door-refrigerator-LFC20760ST.jsp but avoid the big guys. You may have to go to a 10 or 20 mile radius to find a servicing dealer, but it will be worth the effort.
Jan 21, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer shelf doors
Check with the manufacturer, sounds like you have a factory defective freezer. they should fix it for you.
Jul 26, 2009 | LG LRTP1231W Top Freezer Refrigerator
Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Jun 17, 2008 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
201 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
