I'm having problems with my radiator, not heating, and some will only heat parcially, I'm told there may be blockage, how do I unblock, I've taken them apart, and put back together, this oil heat.
  • Vze6msi9 Nov 09, 2010
    I guess you are right
  • 643 Answers
Might need to have an expert come out and flush the system.
Posted on Nov 09, 2010
Over heating problem...changed radiator as i was told blockage in raditor..the problem is still happening...mechaanis says there is no themostat head cakett
Find another mechanic. T stats are automatic on any coolant problem. I could have told you up front the head gaskets were bad. Get away from these point and fix people. The aren't even shade tree mechanics. Could be this, could be that.. I say, this is the problem.
Aug 08, 2015 | Cars & Trucks
Trying to burp cooling system, but when car heats up the coolant shoots out of the radiator like a fountain.. Thermostat is removed, still heats up
You are correct in your suspicions.
The thermostat blocks flow thru the radiator to help the engine warm up. The coolant still flows thru the block with the thermostat closed. If you remove the thermostat the cooling system should flow thru the radiator and stay below 160 degrees if the air temp is below 90.
If the thermostat is out and the engine is getting hot at idle speed, either the water pump has failed, or there is another blockage in the engine block.
Jan 09, 2013 | 1995 Chevrolet Camaro
Over heating
If you had or still have Dexcool in it, thats the orangeish colored coolant its probably a plugged heater core or hose.
Dec 05, 2011 | 1997 Dodge Intrepid
I have a toyota cressida 2.4gle 1992 model.My car heats up after i've travelled about 25km.I've put in a new radiator.The fan is working and i've also replaced the radiator cap,but it's...
Is the car actually heating up?Does the radiator boil?Have you looked at the temperature sending unit giving a bad temp.reading.?The thermostat needs looking at and also the head gasket.Hope this helps
May 25, 2011 | 1992 Toyota Cressida
1995 Dodge Intrepid no heat in cabin. Made sure there is not any air in the coolant system, replaced thermostat and radiator cap. The lower hose that comes out of bottom of radiator is cold. All other...
Radiator has a blockage, it can be removed and taken to a shop to be cleaned out, or a new one can be found on line for a little less than $100.
Feb 08, 2011 | 1995 Dodge Intrepid
We own an apartment building that has the old radiator steam heat powered by a gas bolier .. It heats 11 apartments and 3 store fronts. recently 1 of the apartments called and said that they were not...
the steam is not flowing to that radiator because of a blockage in the pipe or radiator, the valve may have an obstruction or the radiator is water bound. Remove the vent and see if the heat improves. If not, you have a blockage in pipe or valve.
Jan 08, 2011 | Heating & Cooling
Condensate pipe on baxi105he was frozen i have unblocked however still flashing fault led and not working
My Baxi also developed this issue about 1 hour ago. I have about 4m of pipe outside and the blockage is in there.
Inside the bolier on the right I have a clear chamber where the water gathers. Is this still full on yours? If so your blockage is not clear. If it is clear I reset my boiler by using the left most dial and turning it anticlockwise past water/radiator for 5 secs. Should fire up if all is |OK
Jan 09, 2010 | Desa International CBN30T Central Heating...
Over heating
u have a blown engine cylinder head gasket, the engine must be taken apart for repair of this problem.
Mar 13, 2009 | 2000 Pontiac Sunfire
Heating problem
most anccent cars have this problem of heating,here what we do is to replace the radiator with a double cell radiator, if it is single, and or check for blockage of the water circulating system,or on the other hand if the water pump is bad it can course heating problem check the water pump as well.
Dec 10, 2008 | Hyundai Accent Cars & Trucks
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
