Question about Seiko Watches
I have a seiko quartz chronograph sports 100 wrist watch. I need a manual for the watch.
3 Suggested Answers
Techjoel
  • 79 Answers
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Posted on Jun 05, 2009
  • 2501 Answers
SOURCE: Need owners manual for Seiko Quartz Chronograph Sports 150
I feel sure that Seiko will have a copy of the instructions in their archive, so if you contact them they should be able to send you a copy.
(Either that or advise you which watch has similar instructions).
Posted on May 31, 2010
How to change a battery
If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Mar 07, 2015 | Tw Steel Grandeur Diver chronograph Quartz...
May 31, 2010 | Watches
How to set alarm on seiko chronograph sports 100
pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Jan 15, 2010 | Watches
Seiko Chronograph Sport 150 - Problem: After Battery replacement and pressure test (15-Bar), watch hands are not in the correct place. Can this be fixed so the chronograph timing features, and month &...
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Nov 20, 2009 | Seiko SNA553 Alarm Chronograph
INSTRUCTION MANUAL
Your watch is fitted with SEIKO 7T62 quartz movement. Follow this link to download users manual:
http://www.seikowatches.com/support/ib/pdf/SEIKO_7T62.pdf
Rate me, please.
Apr 04, 2009 | Seiko Sportura BAR Honda Racing F1...
Minute Hand on Stopwatch Will Not Return to Zero
Here is the link where you can download manual for your watch:
http://www.seikousa.com/pdf/SNA_Series.pdf
The last chapter explains how to reset hands to zero.
Do not forget to rate, please.
Jan 22, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Second hand doesent return to 1200 position after replace batt
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Dec 06, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Watches Logo
259 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
