Question about Samsung PCL545R 54" Rear Projection Television
Blury picture i adjusted the focus bt still the picture is blury for my samsung 54inch rear propjection tv. wat else can i do?
  • Samsung Master
  • 8,617 Answers
Check the connections on the CRT circuit boards. there is a red wire that slides into the white plastic socket make sure that is connected good, If that doesnt help you may need a replacement focus block, But if so they are very cheap and very easy to install, and I can post a link where you can get one if you need it.
Posted on Jun 16, 2008
The screen is out of focus, the tv will come on but the picture is out of focus it looks like it is being stretched. Words are blury and faces are doubled.
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The convergence board require replacing 2 STK convergnce ICS and some or all of it resistors to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 20, 2011 | Mitsubishi WS-65907 65" Rear Projection...
Picture is bluring...especially the writing..
If you are comfortable working inside the set, locate the flyback transformer (part with large red wire coming out the top.) This part should have 2 controls on it. One should be labeled screen and the other focus. Try adjusting the focus control a bit. If that fails to resolve the focus, please update this with the make and model and additional details will be supplied.
Thanks,
Dan
Jun 13, 2010 | Zenith IQ5299DT 52 in. Rear Projection...
The picture has lost focus and lost green
hard to say for sure, but the front opens up when you remove the bottom or edges. inside you need to inspect the CRT boards for any fluid leaks. there are focus adjustments on a black controller with 3 knobs on it. I would say take a look at the middle tube (green tube) if its dark and the circuit are dry. Try cleaning the CRT pins with the TV off, simply pull the cba/socket down and push it back up.
so lets see no green tube lite , cleaned pins no fluid, next tap it to see if it flashes bright, no OK now on the grn CRT circuit board slowly TV ON turn up the control you see and see if the green gets brighter. The CRTs are fluid filled and the fuild can get cloudy causing it to get dark and blury too. to check the fluid you would need to pull the screen off (a real pain)
these steps will help you isolate the isue and decide what to do next, hope this helps
Eric
Aug 26, 2009 | Samsung HCN5527W 55" Rear Projection...
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Mitsubishi big screen blury
In all probability the picture is fuzzy too, its just harder to notice. This can be as simple as an adjustment in the back of the set. Carefully remove the back and look for the flyback transformer (part with large red wire coming out of the top). The should be 1 or 2 controls on it. One should be marked focus. Adjust that to get sharper focus.
Let me kow if that fails to resolve the problem.
Thanks,
Dan
Sep 30, 2008 | Mitsubishi WS-55807 TV
Picture blury
Its behind the speaker grille up front , remove the grille and then a small access panel and you will see the focus control with 1 button for each CRT 3 buttons in all.
Jun 16, 2008 | Samsung PCL545R 54" Rear Projection...
either your tube lenses are dirty or your focus control is bad.
May 17, 2008 | Samsung HCN4727W 47" Rear Projection...
Focus block is at max still blue
the convergance amplifier have failed there are two of them they need to be replaced. there may be some pico fuses and resistors also. convergance failure is the most common rear projection tv it makes the set appear blury.
Feb 21, 2008 | Hitachi 46F500 46" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
