Question about HP Office Equipment & Supplies
Error 51.10 hp 4250 printer - HP Office Equipment & Supplies
  • 148 Answers
This is what that code means.
51.1 Laser beam detect error
Clean laser beam reference mirror and associated components or replace laser assembly the laser reference mirror in located inside the laser housing.
You are probably going to need a tech to do this.
Hope that helps...
Posted on Jun 16, 2008
The Machine
  • 788 Answers
SOURCE: hp printer problems
Error codes starting with 13 usually indicate paper jams. Open all the doors on the printer and remove any removable modules and check for stuck paper.
Posted on Jan 11, 2008
  • 22 Answers
SOURCE: hp 4250 error code 50.3
Posted on Jun 24, 2008
  • 54 Answers
SOURCE: fuser error on the hp 3700dn printer
You need to replace the fuser since it is most likely caused by a bad fuser. The 50.1 error indicates a low fuser temperature which can be caused by a fuser failure or a DC controller failure. The HP part number for the fuser is Q3655-69001 for a 120V printer. You can also get the fuser as a replacement supply from your toner supplier the item number is Q3655A. Depending on how long you have owned your printer, the fuser needs to be replaced at 50 months or 75,000 pages which ever comes first.
Posted on Apr 13, 2009
  • 1070 Answers
SOURCE: HP printer 4250. am
Welcome to FixYa
Dear User
Do Following Steps Carefully..
  • Turn off Printer Power & Turn it On
  • Unplug Printer power-Re seat EIO accessory in Slot and Switch on Printer
  • power Off printer then Remove EIO Accessory from slot then Install in a other Eio slot and Turn it On..
Still Problem Replace the EIO accessory in slot....
Hope you got it...Thanks for Connecting FixYa..
Posted on Sep 07, 2010
  • 202 Answers
SOURCE: I am getting 60.02
this error comes from tray 2 lifter assembly check the wires harness of motor sitted properly in dc controller pcb
Posted on Oct 10, 2010
Hp 4250 error code 55.4
error code 55.4 on HP Laserjet 4250:-The dc controller is not communicating with
the formatter. The problem could be caused
by a timing error or an intermittent
switch off the unit - disconnect power cord
unsrew the two screws holding the formatter in place
( silver plate to rear right)
remove the plastic side panel by sliding
remove the formatter ( silver box you just unscrewed) by sliding toward the rear.
reinstall the Formatter
and re-test
more often than not just reconnecting the controller is enough to clear the problem. theres a good chance it has moved out of position as time has gone by.
Jan 22, 2013 | HP LaserJet 4250n Printer
Laserjet 4250 error 59.00
I've found this specific error code leads you to a main motor failure, Ive found some decent priced motors if you need them: HP 4250 Main Motor
Aug 30, 2011 | HP LaserJet 4250n Printer
Hp printer 4250 is error 50.0
Fuser Error, Replace the Fuser (Part Number RM1-1082) In the rear behind the door very easy to do.
Dec 29, 2010 | HEWLETT-PACKARD Hewlett Packard 21A - HP...
I am getting 60.02 error on my HP laser jet 4250 printer
Sep 21, 2010 | HP LaserJet 4250 Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href=""></A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware.
Mar 20, 2008 | HP LaserJet 4350 Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
Hp printer problems
Jan 11, 2008 | HP Color LaserJet 2600n Printer
2,750 people viewed this question
Ben Johnson
