Question about Kyocera Office Equipment & Supplies
Paper coming out black - Kyocera Office Equipment & Supplies
  • 113 Answers
The main charger is faulty. clean main charger if not working replace the main charger.
Posted on Nov 10, 2010
Paper comes out black
Check the image unit. And check the charge grid on the top of the drum. also check the three little springs that the top of the machine comes down on under the image unit.
Feb 28, 2014 | Minolta EP1031/1031F CS/PRO Copier
Shredded shiny paper
The tan and black paper that is coming out of your printer is the Teflon fuser sleeve that has torn and coming apart. The fuser is the part of the printer that melts the toner onto the paper. The Teflon sleeve in the fuser is where the heat comes from. When the sleeve gets worn down it can tear and you get the little pieces coming out like you have. You will need to replace the fuser unit in the printer to correct this issue. The fusers are available from Amazon and other web sites and they are user installable. The part number is RG5-2657 or RG5-2661 either parts number will work in your unit.
Apr 09, 2013 | HP Laserjet 4000 Series Printer 27920 Page...
Hello, our printer prints with lots of black smears on the paper. I am using white paper and it comes out looking like I colored the whole page with black crayons. How can I fix this?
Try changing the toner first, if you have one accesible. If the toner is coming off the paper on your hand you need to replace the fuser.
Jan 17, 2011 | Dell 1320c Laser Printer
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Black not printing properly
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer........
Good Luck
May 07, 2009 | HP PSC 1210 All-In-One InkJet Printer
Black cardstock
There is no white ink in the printer. White needs to come from the paper.
The inks in your printer can only make your paper DARKER, and you can't get any darker than black.
Oct 08, 2008 | Lexmark P6250 All-In-One InkJet Photo...
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
