Question about Zebra Eltron LP 2824 Thermal Printer
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
    Champion:
  • Zebra Expert
  • 285 Answers
Check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Posted on Nov 23, 2010
Lp 2824 plus won't print. Have windows 7 till switch off and on again
printer driver conflict or windows 7 driver incompatibility. contact zebra for proper driver installation.
Oct 21, 2014 | Zebra LP 2824 Plus Label Printer
Zebra LP 2824 Plus Giving Endless Labels
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Dec 07, 2012 | Zebra LP 2824 Plus Thermal Label Printer
Zebra LP 2824 not printing a barcode
check the driver if the length and the with are correct, print a test page, check if come the windows logo and the test from all label. check if the barcode is biguer that the label, if it is, is not appear.
2 solution is to reset printer to factory defult (press button until flash 4 times and relese the button.
Aug 19, 2010 | Zebra Eltron LP 2824 Thermal Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Barcodes print too long
This is defendant on the program you use to print labels with. The printer responds to either a print job sent to the driver (like a standard windows printer). Or you can send an EPL program to the printer in order to use internal barcode generating features of the printer. The dimensions of the barcode are controlled via the EPL script. See the EPL programming guide avaialble on Zebra's website for more info.
Feb 27, 2008 | Zebra Eltron LP 2824 Thermal Printer
Slow printing to LP2824
This appears to be normal operation.
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra Eltron LP 2824 Thermal Printer Logo
502 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
