Question about Dell E178WFP LCD Monitor
When I power up my monitor power light just flashes any suggestions
  • 11,361 Answers
Please read my instruction and look at the pictures of failed DELL monitors.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Nov 09, 2010
Flashing green light on the circuit board. No power at all
I suggest it is the mother board or the power supply. Go to the Dell website on a friend's PC and download PDF manuals pertaining to your model. The battery may have enough power to light an LED.
Jan 08, 2014 | Dell Dimension XPS PC Desktop
Power light flashes monitor does not turn on hear little chirping sound and see a little light flashing inside the back of the monitor
Check and replace burned high voltage ballast transformer and busted backlight inverter...
Too risky to do it yourself without proper knowledge and right tools..
Suggest you bring your monitor to a credible technician to have your parts replace and avail of warranty if there is still..
Much apprreciated if you rate this help..thanks..
May 24, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Samsung
Please try to connect your monitor to another PC, if still the problem exist, then probably an internal electronic part/s is cold soldered / defective, which I suggest to bring the unit to an authorized service center to fix the problem. regards
Jun 02, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Monitor won`t light up.
Something got faulty on the power section.
I suggest you take it to those who knows about its technical.
Mar 17, 2008 | Gateway FPD2275W LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Dell E178WFP  LCD Monitor Logo
50 people viewed this question
Clive
Clive
Alun Cox
