We removed the exsisting nutone fan and replaced it with the Panasonic whisperfit. We are getting odors in the bathroom when the fan is on and also when it's off. I poured smoke underneath the fan to see what direction the air was moving and indeed the smoke traveled out however, it seems that not all of the air is moving out sum of it backs up into the bathroom. Can anyone help?
-   I recently installed a fan in the bathroom. When it is off, there is no air coming in, however when i turn it on, it seems like half the air comes back down. I have checked and the flap is working fine, things seem to be connected ok. Any suggestions?-   mglasrud
try to install the fan at a lower height so that it can drive out all the smoke. This is because the fan can driveout air with in a certain radius and installing it at a lower height increases it..
Light bulb must be out. Cannot remove glass at the very bottom to access bulb area in order to...
(More)
Light bulb must be out. Cannot remove glass at the very bottom to access bulb area in order to install replacement bulb . UL 96H7 E 77491 Model 54 SHRL 11688 09/04 0041681
we have an electric freestanding fireplace made by SOuthern Enterprises, model # FA503000 TX. it has...
(More)
we have an electric freestanding fireplace made by SOuthern Enterprises, model # FA503000 TX. it has totally quit working. I was working one day, then nothing the next. I thought maybe it had been unplugged, but everything is plugged in correctly. Is there a fuse or something somewhere or batteries that we may could check? Obviously, we have lost the manual. Thanks for any feedback you can give.
Trying to install new hunter 44155c...my old thremostat has diff letters...I have B,G,Y,R,W and...
(More)
Trying to install new hunter 44155c...my old thremostat has diff letters...I have B,G,Y,R,W and O...could you please help me with the new one on where these wires should be placed
My heater's internal thermometer is too sensitive. It shuts itself off after being on for only a...
(More)
My heater's internal thermometer is too sensitive. It shuts itself off after being on for only a minute. This is supposed to be a safety feature, but it means that I can't use the heater. Any suggestions?
Thank you Eagle338 for your assistance. I should mention that the nutone fan was originally located...
(More)
Thank you Eagle338 for your assistance. I should mention that the nutone fan was originally located on the wall and we installed the panasonic fan on the ceiling at the same distance that's why I do not belive my problem is an increase in static pressure. The fan is mounted flush on the interior side of the dry wall I do not understand what you mean by installing it lower. Lower to what? Thanks
