Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I have had trouble installling the kodak printer and then i read where you should uninstall the software but since it was unable to remove how do i do that?
  • Kodak Master
  • 7,733 Answers
Go to control pane and select Add/Remove 9xp) or Uninstall a program(vista,7) and select it.
Posted on Nov 09, 2010
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
Having trouble installing a Kodak ESP.3 printer, can anyone help.
Reinstall and then install it again should work....
Jun 25, 2009 | Kodak ESP 5 Printer
Can't find driver for printer?
Try uninstalling the printer driver and then reinstall.
Answer : To uninstall the drivers and all-in-one home center software:
  1. Disconnect the printer from the computer.
  2. Select Start>Settings>Contol Panel>Add or Remove Programs.
  3. Select the Kodak EasyShare all-in-one software.
  4. Click Remove.
  5. When "Click Next to add or remove KODAK EASYSHARE Software components" appears, click Next.
  6. Select Remove.
  7. Click Next.
  8. When the Uninstall Complete window appears, click Continue.
  9. Restart your computer.
var solutionBaseUrl = '/service/main.jsp?t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId='; var transactionFragments = document.getElementsByName("transactionFragmentForm"); var solutionLinks = document.getElementsByName("solutionLink"); atgss_loadFragments(transactionFragments); atgss_modifySolutionLinks(solutionLinks);
Jun 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Unable to access Kodak EasyShare software
Perform a clean uninstall:
1) uninstall the software from your OS
2) run the clear utility program www.kodak.com/go/clear
3) type "regedit" w/ out the quote on the run command, then delete hkey_local_machine\software\kodak
4) run disk cleanup
remove the ff:
  • Downloaded Program Files
  • Temporary Internet Files
  • Recycle Bin
  • Temporary Files
5) reinstall the software again at www.kodak.com/go/edl
May 29, 2009 | Kodak EasyShare Z760 Digital Camera
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak EasyShare 5300 won't install on my Mac computer
go to your control panel and uninstall any printers including kodak then restart you computer, then try installing your kodak, Rob
Feb 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Can't get picture to scan
try doing this procedure to fix the issue.....
To perform a clean installation of the KODAK AiO Home Center software, follow the instructions below:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the KODAK All-in-One Printer Software:
    a. In the Control Panel, select Add or Remove Programs (WINDOWS XP Operating Systems) or Program and Features (WINDOWS VISTA Operating Systems).
    b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
      • Kodak EasyShare software
      • KODAK All-in-One Printer Software
      • Kodak EasyShare 5000 series all-in-one software
    c. Click Change or Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA OS).
    d. When the Install Wizard appears, click Next.
    e. Depending on the issue(s) you are experiencing, do the following:
      • If you are experiencing errors with KODAK EASYSHARE Software, such as a tri-code, in addition to errors with KODAK All-in-One Printer Home Center Software, select Remove, click Next, and follow the on-screen instructions for removing the software.
      • If you are not experiencing errors with KODAK EASYSHARE Software, select Modify to uninstall only KODAK All-in-One Printer Home Center Software, then click Next.
    f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
    g. In the Ready to remove the program window, click Next.
    h. In the Uninstall Complete window, click Continue.
    i. Restart the computer.
IMPORTANT:
    • If you selected Modify and only uninstalled the KODAK All-in-One Printer Software and did not uninstall the KODAK EASYSHARE Software, continue to Step 4.
    • If you selected Remove and uninstalled both the KODAK All-in-One Printer Software and KODAK EASYSHARE Software, continue with Step 3.
3. Run the Clear Utility to delete any previously installed KODAK All-in-One Printer Software components:
    1. Got to www.kodak.com/go/clear to download the Clear Utility for KODAK EASYSHARE Software.
    2. Select your operating system from the drop-down list and click the Download button to save the file to your desktop.
      Note: If the status indicator on the Clear Utility stops, check the taskbar on your computer for an active security program. If a security program appears in the taskbar, it may be prohibiting the Clear Utility from running. You must allow the Clear Utility to run on your computer before you can continue.
4. Delete the files and folders that can interfere with the installation.
    For WINDOWS XP OS, delete:
      • Printer folder in C:\Program Files\Kodak
      • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
      • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
      • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
    For WINDOWS VISTA OS, delete:
      • Eastman Kodak Company folder in C:\ProgramData
      • Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
5. Run Disk Cleanup:
    1. Open My Computer.
    2. Right-click Local Disk (C:) and select Properties.
    3. Click the Disk Cleanup button.
    4. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
    5. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
    6. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
6. Shut down all background applications.
    1. Select Start > Run.
    2. Type msconfig in the Open field, and click OK.
    3. Select the Startup tab.
      IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
    4. Click Disable All , then click OK .
    5. When prompted, restart the computer.
7. After the computer restarts, install the latest version of the KODAK All-in-One Printer Software as a free download from the Kodak Web site at www.kodak.com/go/downloads.
    • If the customer has the latest version of the KODAK All-in-One Printer Software on CD, install the software from the CD.
8. Before restarting the computer again, turn on the background applications.
    2. Type msconfig in the Open field and click OK.
    4. Under Startup Items:
      - If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
      - If all background items were originally selected, click Enable All, and click OK.
9. Restart the computer.
Nov 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Uninstall kodak easyshare
Hi there
Thanks for posting your problem on fixya
Thanks for providing us all the details you unable to install because you have aio still on your pc so please do these simple steps
click on start>> go to run>> type >>msconfig>> and go to startup and find that aio and please uncheck that aio and reboot your pc.
After rebooting your pc you are able to install what u want
if this solution works then please vote for me
Thanks
Robert
Sep 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Software Installation problem gets stuck - all in one Kodak ESP3 printer
I have a 6 year old Dell with XP, plenty of hard drive and memory. I could not scan using the software, I went on the Kodak website and followed the Step-by-Step Solutions and Repair which nothing worked, including the Kodak Clear Utility they reccomend for ridding your system of the software, it just locked up at the end.
So, I spent several hours on the phone with Technicians trying to uninstall and reinstall the ESP3 software. None of their methods worked even step by step manually un-installing every file and folder...
So I wrote a nasty email to them and they sent this back, which by the way, didn't work for me either, but maybe it can for you.
According to your email, the issue is that you have not been able to install the software for the printer on your computer. We understand the importance for you to have your printer working properly.
To help resolve this issue, please follow these steps in the order they appear:
2. Uninstall the Kodak EasyShare 5000 series all-in-one software:
a. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
Kodak all-in-one printer software
c. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
3. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
a. Printer folder in C:\Program Files\Kodak
b. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
c. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
d. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
b. Eastman Kodak Company folder in C:\ProgramData
c. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
4. Run Disk Cleanup.
a. Open My Computer.
b. Right-click Local Disk (C:) and select Properties.
c. Click the Disk Cleanup button.
d. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
e. Click OK, and then click Yes to delete all files and begin the Disk Cleanup.
f. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
5. Shut down all background applications.
a. Select Start > Run.
b. Type msconfig in the Open field, and click OK.
c. Select the Startup tab.
d. Click Disable All , then click OK .
e. When prompted, restart the computer.
6. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
a. Insert the printer software CD into the CD-ROM drive.
b. In the KODAK EASYSHARE 5000 Series All-in-One Software window, click Next.
c. Select CD Installation, and click Next.
d. Select I accept the terms of the License Agreement, and click Next.
e. Select Custom, and click Next.
f. Select Not Installed for every feature, and click Next.
g. When To begin the installation process appears, click Next.
h. Select Remind me later to register, and click Next.
i. When the Kodak Statistics Collection window appears, select Yes, and click Next.
j. When prompted, connect the printer to your computer.
k. Click Next when the Next button becomes active.
l. When Congratulations, your Kodak printer has been successfully setup appears, click Finish.
m. Click Continue, and then close all windows.
7. Before restarting the computer again, turn on the background applications.
b. Type msconfig in the Open field and click OK.
d. Under Startup Items:
8. Restart the computer.
Aug 30, 2008 | Office Equipment & Supplies
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
1. Open the Control Panel.
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
3. Select Microsoft .NET Framework 2.0.
IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
1. Follow steps 1 - 4 above.
2. Select Uninstall, and click Next.
IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
3. Restart the computer.
4. Perform a clean re-installation of the KODAK AiO Home Center software:
a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
NOTE: Do not disconnect your mouse or keyboard.
b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
vii. In the Ready to remove the program window, click Next.
viii. In the Uninstall Complete window, click Continue.
ix. Restart the computer.
c. Delete the files and folders that can interfere with the installation.
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
d. Run Disk Cleanup.
i. Open My Computer.
ii. Right-click Local Disk (C:) and select Properties.
iii. Click the Disk Cleanup button.
iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
e. Shut down all background applications.
i. Select Start > Run.
ii. Type msconfig in the Open field, and click OK.
iii. Select the Startup tab.
iv. Click Disable All , then click OK .
v. When prompted, restart the computer.
f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
h. Before restarting the computer again, turn on the background applications.
ii. Type msconfig in the Open field and click OK.
iv. Under Startup Items:
- If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
