Question about Kuppersbusch EEB62001 Electric Single Oven
I have a Kuppersbusch EEB 62001. There is no heat, no fan, no light. I have checked the fuses (i.e. the fuse box and the main switch in the kitchen). The over is only 4 years old and has not been used too much. Where should I start, the electrics or the oven? Thanks
Tomwillfixit
  • 5 Answers
SOURCE: fan is running fine but main oven does not heat up
It is most likely the element they are very cheap on line ,
Posted on Oct 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Necht model 720 built in electric oven. Fan
If the oven fan is working o/k, thenyou need to replace the fan oven element.
Please rate my solution.
Thanks.
Posted on Sep 16, 2009
SOURCE: I need a cleaning product for the inside of my
I have asked someone in the customer service department.
Posted on Dec 02, 2009
  • 417 Answers
SOURCE: fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Posted on Dec 31, 2009
  • 417 Answers
SOURCE: main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Posted on Jan 04, 2010
Oven not working front lights for main switch and thermostat and internal light not coming on oven wont heat only fan is coming on oven 1 year and a few months old
Check if a overtemp fuse has beem avtivated. You will need a multimeter. Check for burned wires on function switch and thermostat. And check functionswitch for burn marks. Function switch = main switch
Feb 13, 2016 | Ovens
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
Switched bottom oven on, then noticed it had tripped fuse for cooker in main fuse box. Swithed it back on and it wouldn't heat up. The fan and light were ok! Top ove? grill works ok still.
sounds like you have a heating element burned out. Look real close at the heating elements and you may see a hole burned in the metal tube. This is a sure sign of a bad element. Some elements are easy to unplug. Others a real pain. Always unplug and or turnoff breaker prior to unscrewing anything. If you fine the bad element just unplug and other element may work OK. Best to get your model number and search net for new element.
May 30, 2011 | Ovens
I need a Manual for EEB 6500 stove in ENGLISH
You can get the manual on the link below.
http://www.kuppersbuschusa.com/Documents/Use_Care_Guide/EEB6500_8_UandC_Guide.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 19, 2010 | Kuppersbusch EEB 6600.0 MX Stainless Steel...
Oven not heating, and tripping .Aeg Electrolux
check your heating ellement
Mar 24, 2009 | Ovens
Kuppersbusch EEB9800.0 oven - thermostat sensor defective
you need part number 165047 cable harness and part number 161629 thermostat pt1000 call currys partmaster and get a quote on the parts
Aug 26, 2008 | Kuppersbusch EEB 6800.0 JX Electric Single...
Message 007 displayed on right display
My kuppersbusch dishwasher drawer (detachable plate rack piece) is rusty. Where can I find a replacement?
Nov 08, 2007 | Kuppersbusch EEB 6800.0 JX Electric Single...
Kuppersbusch EEB62001 Electric Single Oven Logo
78 people viewed this question
Top Kuppersbusch Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Kuppersbusch Oven Expert? Answer questions, earn points and help others
