Question about DeLonghi Heating & Cooling
I have a DeLonghi Aurelius Electric Fire. The bulbs wont light up. I have checked the bulbs and internal fuse , they are ok..is it posible to wire up so that the bulbs come on with out the use of the remote control..any suggestions, can it be fixed.?
MicrowaveSvc
  • 9098 Answers
SOURCE: delonghi combi microwave
It may be the internal fuse, or the thermal fuse / thermostat / thermal cutout on the magnetron. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
martin538
  • 117 Answers
SOURCE: brake lights wont work
Check the brake light switch which is located above the foot pedals on a metal bracket.
Posted on Apr 07, 2009
SOURCE: I have a 2001 mk4 Golf GTI. I replace a rear light
I have this problem, it's fuse number 14.
Posted on Aug 22, 2009
Testimonial: "Thanks very much - instant result!! Much appreciated."
  • 1382 Answers
SOURCE: My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Posted on Sep 05, 2009
BLAZZ81
  • 281 Answers
SOURCE: speedometer gauge/climate control lights dont work
Look for a dimmer wire,, sounds like your radio dont have the option for the car dimmer switch,,
the power for these lights run through the dimmer wire for the radio. ether its not hooked up or the radio dont have the option for it.
there is a way to bypass the radio dimmer option,, BUT you have to know what your doing or you could fry something.
look for Car Radio Illumination/dimmer Wire: should be Green.
Posted on Nov 27, 2009
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
Will not start. Fuel pressure ok, new plugs and wires. Turns over, wont start. What to check next?
Check for spark at 1 or more plug wires. If no spark, possible crank sensor/computer/fuse/wiring. Check for injector pulse. Remove 1 injector harness and install test light between the two terminals of the harness and crank engine. Test light should flash if computer/wiring ok. Make sure check engine light comes on when key in on position for bulb check. If no light, look for blown ECM fuse/s
Oct 18, 2015 | 2004 Chevrolet Chevrolet Tahoe Z71
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
My 1999 Isuzu Roder keeps popping the fuses for the backlights and now it wont start
When the fuse for the back lights pops, does the radio stop working? If yes, then you will need to check for a short-to-ground in the area of the radio where your husband hooked up the memory wire- possibly the insulation of the wire has rubbed through and is touching metal somewhere, or perhaps the electric tape he used to cover the splice has fallen off. If the radio still works with the back light fuse blown, then it is highly unlikely that the radio has anything to do with the matter. In past experience, I have seen a Ford pickup with a similar problem, and it turned out that one of the taillight bulbs was shorted internally. Very unusual, but happened nonetheless. Good Luck!!
Nov 06, 2011 | 1999 Isuzu Rodeo
My passenger side brake light socket keeps melting the bulb where it connects, after replacing the bulb several times it wont work at all. also everytime i try to use my cigarette lighter it wont work and...
it sounds like that your car has an open short in the wiring somewhere, i would 1st check the wiring of the brake light that you are having trouble with, and if that checks out ok, then , i would check the fuse box area. and the wiring to the cigarette lighter, the wire connection to it , could be shorting out, by means of the wire being worn and shorting out against the metal.
Apr 23, 2011 | 1995 Chevrolet Cavalier
I have a wall mounted electric fire with flame option,I have changed the bulb but cannot get the flame effect to work. The falme wheel is turning but no light effect.
have you checked fuse to bulb some electric heaters have a fuse for bulbs and fans so it might be a small inline fuse that you need to change
Nov 22, 2010 | Heating & Cooling
Brake lights wont work
Hi. Check for blown fuse inside the fuse box expecially for the brake light fuse. if fuse are ok, check the bulbs. If bulbs are working fine then this could be a wiring problem.
Sep 21, 2010 | 1990 Buick Regal
I have no brake lights. I replaced the bulbs. Checked the fuse and even pulled the brake light switch. Those are ok.. Help please!!!
good day, you may want to see an expert electrician for faulty wirings, faulty wirings sometimes results to fire and we dont want that to happen... have a nice day
Feb 11, 2010 | Car Audio & Video
No current to bulb. at licence plate.
did u check tail light fuse underhood fuse center,if that fuse is blown ,tail lights on trailer and lic. light on truck wont work,if ok,check elect. circuit for broken wire.at trailer plug or conn.
Mar 19, 2009 | 1997 Chevrolet K1500
Heating & Cooling Logo
107 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
