Question about Nikon D80 Digital Camera with 18-135mm Lens
NIKON D80 MY SHUTTER SPEED WILL NOT GO PAST 1/200 SEC. WHEN I ROTATE DIAL. WILL GO TO ANY SETTING BELOW THAT.
  • Anonymous Jun 21, 2008
    Having the same problem. I use SB800 Flash, and it seems, that the max shutter speed stocked at 1/200 (max flash sync shutter speed) regardless of the setting in M or A mode. Yesterday it worked. Today its not. So its not a setting problem. Rather a bug in firmware??? Tried everything, reset, etc. Nothing helps.
  • Anonymous Nov 30, 2008
    I tried turning my flash off and it lets me adjust the speed, but what about when I need my flash on?
    Sniper:
  • 53 Answers
Check that your flash is not up. Or if you have an external flash, turn it off.
Posted on Jul 22, 2008
Where is the aperture ring on d80 Nikon
If you are using an older lens the aperture ring will be close to the camera body when the lens is on the camera. In order to set the aperture with a D80 and older lens you must set the aperture ring to "22" or the highest number on the aperture ring available. For newer lenses there is no aperture ring. You set the aperture by setting the dial on the top left of the D80 to "A" for Aperture Priority. You then set the aperture by rotating the front dial on the right side of the camera under the shutter release button. On older lenses, after setting the aperture ring to the highest number, you then set the aperture in the same manner.
Sep 22, 2014 | Nikon D80 Digital Camera with 18-135mm...
Vivitar 84mm 1.4 aspherical on Nikon D80
If you mean the 85mm, it's not an autofocus lens. Nor does it have the electronics to communicate with the camera. You need to set the camera to manual exposure mode (turn the mode dial to M) and set the exposure manually. Set the shutter speed by turning the command dial on the back of the camera and the aperture by turning the aperture ring on the lens.
Again, this is a manual lens. No auto-anything. But it's a nice fast lens, with shallow depth of field when you want it.
Jan 10, 2013 | Cameras
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
Can't get shutter speed any higher than 1 sec
It's on the lens, it will show you the higher speeds for the camera. It should go up from 5.5 to 6.5 etc. that's your shutter speed.
Mar 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
In manual mode cannot set shutter speed to
The "--" is the equivalent of the bulb setting with the remote control. The first press of the button opens the shutter and starts the exposure. Another press of the button closes the shutter and ends the exposure. This is so you don't have to hold the button down and risk a bird flying through the beam (and to conserve battery power).
Sep 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
There is a message in front of my picture on the monitor
When viewing pictures in playback mode, simply turn the index finger dial (up by the shutter button) and this will change the 'mode' in which you view the pictures and should eventually get you to a setting where this information disappears.
Jan 19, 2009 | Nikon D80 Digital Camera with 18-135mm...
Can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
Jan 12, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter speed on my nikon d80 is to slow
Try CUSTOM SETTINGS MENU 31. (turn off EXP. delay mode).
Dec 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
Shutter priority shooting
Gigi215, Change your ISO up until the speed is at least 1/60th, then see if that helps. randy320sgi
Oct 04, 2008 | Nikon D80 Digital Camera with 18-135mm...
Dark Picture
I am assuming the following two things.
1. The part was indoors.
2. You are using the 18-135 mm lens with the Nikon D80.
The problem with shooting indoors is that not enough light goes in through the lens to the filter. Solutions:
1. Use the flash with every shot. In case there is not flashlight available, use the on board flash. Press the top button behind the barrel on the camera. It has a lighting icon. It will pop open the flash. If you are in 'P', 'A', 'S' mode, the camera will sync the shutter speed with flash. If the camera is on auto mode (The green camera icon) the flash will pop up and fire by itself.
2. Use the lens with with lowest f stop, i.e. with bigger aperture.
3. Increase ISO. You ought to get usable photographs right up to 800. To change ISO, press the button on the back of the camera which says 'ISO' (Second button from bottom) and turn the primary command dial simultaneously to change ISO setting. Higher ISO speed = Lower shutter speed (But less clarity too).
Hope it helps.
Satdeep
Jun 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
