Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
I have lost the suction and cannot get it to **** up the water.
How to fix lost suction
Check for a blocked suction intake hose.
Jul 07, 2017 | Vacuums
Why does it leave a lot of water on the floor
Clean out the filters, It has lost some suction and suck up the water.
Mar 28, 2015 | Vacuums
It has lost suction
Have you got suction just before the motor? How about air coming out the exhaust?
Mar 14, 2015 | Vacuums
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow has no suction
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
Thank you,
Ralph
Jan 27, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Halo main suction motor will not come on
Used my Steam Vac twice and now there is no suction where the unit should be picking up the water layed down from the sprayer. I've readjusted the collection tank, took the lid off and made sure the side clips were snug and cliped against the tank, but still no suction. I don't hear any unusual noises, the handle lays down, water spits out, it just has lost suction. Any suggestions? With Appreciation, -kb
Sep 30, 2009 | Vacuums
Lost suction
there is a screen by the brush that may be clogged. Make sure the water tank is on tight
Feb 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
http://bissell.com/images/schematics/1950.pdf
Jan 29, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
269 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
