Question about Pioneer DEH-P7400 CD Player
How do i reset the unit? after my battery died got a new one now the only sound is through the rca output
  • ratpuncher Nov 10, 2010
    you would think so but if there is one nobody i know can see it
  • 87 Answers
There is a small reset button that you can push with the tip of a pen on the front or detach or drop the face and you should see it.
-david
Posted on Nov 09, 2010
RCA Reciever no sound
You could have speaker wires shorted, putting unit in output shutdown. check them. Turn unit on and listen very closely for about 5-6 seconds for a click (the relay for okay output condition). If not heard, have unit serviced or check for blown output fuse. Of course they don't blow without a reason.
Aug 23, 2016 | RCA Audio Players & Recorders
How to instal a amp and sub on a OE stock radio
If you want to upgrade your sound system in your car by adding a sub woofer or speakers powered by an auxiliary amplifier without having to get a new head unit then hopefully this should help you :)
I decided to keep my standard head unit because it looks well in the car, is less likely to attract thieves than a shiny after-market unit and it is a factory upgraded unit anyway and i find it gives pretty good audio quality, it works with the steering wheel controls and has bluetooth and aux-in, so an after-market unit wouldn't offer a substantial upgrade.
Factory head units rarely have RCA or "Low line" outputs which your amplifier will need for it's input signal.
A "Low line converter" is a device which will piggy back your speaker outputs from your head unit and convert them to Low Line RCA outputs for your amplifier
The converter i bought also gives you a "remote wire" output which tells your Amp when the car is on so it doesn't drain your battery, if you get a converter without this option you can just join the remote wire to the Acc circuit of your car, or the 12V circuit with a switch (you will have to remember to turn it off though or your amp will drain your battery)
The methods i used will require an understanding of car/car stereo electrics so just be careful so as not to damage your car or yourself :)
Locksmith Orchard Park Ny 24 Hour Locksmith 716 848 0099 in Orchard Park Ny
Jun 04, 2016 | 2006 Chrysler Pacifica
I have an RCA RTD3136 theater system, bought new in 2013. Worked fine for a few months, then started going out occasionally. I'd unplug the unit and reset, and it would work fine,for a while.
It sounds to me like the audio output transistor or IC is going bad,or the unit is overheating.Try blowing the unit out with canned air and relocating it so it can(breathe)<dissipate heat .
Nov 12, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
Can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Jun 05, 2009 | Clarion M255 AM/FM Marine CD Player
Subs not as loud as they should be plz help
RCA output level and speaker level output have different voltages and currents. The problem you are describing is common to folks trying to connect an OEM dash unit to an aftermarket amp. If your amp has speaker level inputs, try wiring to those......best bet..buy a new head unit, it'll sound better...louder and cleaner.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 11, 2009 | Kicker IX404 Car Audio Amplifier
No sound on my kam uhf wireless mike
wire loose inside handset, or receiver output problem. wiggle the handset wires and listen for crackling. if so, repair or replace.
Jan 26, 2009 | RCA EZLINX 3 BNC male plus 2 male to...
Power on green light is on but no sound when speakers are hooked up
Light is on so suggests power, earth and remote turn on cable all ok. Now you just need to test the RCA signal and the AMP output. I take it you have used low level RCA as the input from the head unit? (two cables usually red n white although can somtimes be other colours) best way is with substitute amp n speakers etc although can be done with osciliscope or headphones. Once it is established the RCA signal is fine then you can check the speakers from the amp. disconnect them at the amp and put each of the two wires briefly to a battery, any battery will do e.g. 9v PP9 or 1.5v AA etc you should hear a pop from each speaker as you do it. that proves the speakers and wiring to them.
If there was no signal from the RCA the cables may be bad - requires testing from head unit to amp
failing that the RCA output may be reduced or turned off via a menu in the head unit
Or the RCA output from the unit may be knackered.
Sorry its a bit long hope it helps
Luda
Jul 04, 2008 | Jl Audio Car Audio & Video
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
RCA 5.1-Channel 250 Watt Home Theater System - Model RTD209
Unit was working fine,took a movie out,put in new one,but would not play.Tried hitting open button ,unit will not respond,all other functions working ok.
What could be the problem,is it worth fixing?/Is there a reset button somewhere on unit?
Oct 27, 2007 | RCA RTD209 System
Pioneer DEH-P7400 CD Player Logo
113 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
