I have lost the wiring directions for my MTH firehouse. Can you let me know the wiring diagrams for basic operation?
Thanks,
Roger Alt
[email protected]
I went through the same searching drill you just did and came up with the same negative results.
The product code is R8012 and the model number is HM2000. (Forum searches also)
Hello jimmyborrego: My name is Roger and I will help you. I attached a picture of fire order and wire location. The fire order is 1-6-5-4-3-2. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Hello mtripp: My name is Roger and I will answer your question. The neutral safety switch is located on a bracket directly above the clutch pedal. Should have two wires that plug into it. One should be white with a blue tracer and the other wire should be black with white tracer. Should you need further help please just ask. Please rate the answer you received as this way i know it was helpful. Thank You for using Fix Ya. Roger
A) on the gas station gets one wire from the transformer and one to the activation botton off A on gas station ( acc power from transformer )
B) gets ground from the transformer
C ) to activation botton
D ) to Acc power on transformer
E ) ground on transformer
Hello kahumada1: My name is Roger and I will be glad to help you. The fire order is 1-3-4-2. The coils should be marked. Hear is a picture that should help. Please rate the quality of your answer as this is how we know your answer was correct. Thank You for using FixYa.Roger
