Question about Haier HSQ04WNA Compact Refrigerator
I have Haier - HSQ04WNAPG and it's been working for 4 good yrs. but just discovered 2 days ago that both the freezer & the refrigerator is not cold, I always set the temp to no.4 , the motor at the back is hot but it's not cold inside. Please help. Thanks.
  • 547 Answers
SOURCE: Refrigerator seems to run all the time
Hey Wisper, I had a very similar problem with my Haier. Read all about it here: http://www.fixya.com/support/t180574-freezer_10_deg_fridge_50 I replaced the thermostat ($35 or so, mail ordered) but that didn't do very much. Then I replaced the Evaporator fan ($40 for an OEM part, read the details on my other page) and that did the trick. Feel free to email me if you want more details of what the job involved. I'm @gmail.com and the address is RobCuthbertson
Posted on Sep 13, 2007
fridgetech
  • 473 Answers
SOURCE: Haier HNSE05 shuts off on it's own.
Sounds like the thermostat is bad which is temp. dial.
Posted on Oct 06, 2007
watugot
  • 290 Answers
SOURCE: Refrigerator temp
If it has a refrigerant leak, replace the fridge. Not many techs service r-12 refrigerant systems anymore because the cost is rediculous. The cooling problem could be associated with the leak or a defrost system failure or a fan motor failure. Almost anything that will cause this will require some parts to be replaced. I wouldn't recommend repair on a unit with gas leak.
Posted on Oct 08, 2007
Bgillespie
  • 89 Answers
SOURCE: Refrigerator not cold
It sounds to me like you have a defrost problem. Look on the back wall in the freezer about 3/4 of the way down. Do you have any frost build up? If so, for me to be able to help you futher I will need the model number of the refrigerator located on the inside of the refrigerator...
Posted on Dec 15, 2007
  • 263 Answers
SOURCE: hot refrigerator
defrost problem check the defrost to see if thats always working
Posted on Dec 30, 2007
Refrigerator turns off restart a couple days later haier hnde03
the is an electronic timer for defrost mode on all frost free frig/ freezers it goes bad to find that in your frig call the manufacturer or a good repair man
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
Odor eminating from freezer
Dead mouse or rat is a definite possibility.
May 04, 2017 | Haier RRTG18PABB (207 cu ft) Refrigerator
The freezer is coated with frost and the top will not cool. Had this problem 2 yrs. ago and repairman charged 200.00. I defrosted freezer and top part is cooling, but this is a temporary fix. I don't know...
Good day,
The defrost system has had another failure. The system is made up of 3 parts.
The first 2 are located in the freezer behind the rear panel. They are the main heater which is a calrod unit mounted to the bottom of the cooling coil, and second, a defrost thermostat, which is a small round disk which is clipped to the top of the same coil.
Both can be checked with an ohm meter. Unplug the machine, and while it is still cold, check both with the meter. The thermostat should check zero ohms, the heater no more than 30 ohms. The thermostat is usually the culprit, with the calrod heater failing rairly.
If both check O.K. then it is the adaptive defrost control, which is located in the roof of the fresh food compartment. It fails fairly often, and is the most expensive.
With the complete model number, call your local appliance parts house for prices.
Apr 04, 2010 | Maytag MFF2557H Bottom Freezer French Door...
Broke small pipe going to freezer compartment
Good day,
No reasonable repair possible. That is a refrigeration line. The repair would exceed the price of a new unit.
Defrosting these machines should be done with a fan only.
Feb 05, 2010 | Haier HSB03 Compact Refrigerator
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Nov 07, 2007 | Haier Refrigerators
Haier HSQ04WNA Compact Refrigerator Logo
82 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
