Question about Refrigerators
I have a KitchenAid Refrigerator, model # KSS048FMX01.... The problem is all of the lights do not come on at all ----both in the freezer , and in the refrigerator itself. Are the bulbs on a series circuit?? Or is the a reset button, or separate breaker for the lights?? If so, I cannot seem to find it. I cannot locate a door switch either. Please advise, Thanks, Ted
aborcass
  • 2651 Answers
SOURCE: Kitchenaid refrigerator dispenser not working
possible bad switch, but that would only control onr of the features, sounds like your have an power supply issue to the entire door assy , check the incoming waire s eiterh on top or bottom of door hinge, look for broken/unplugged wire harness
Posted on Apr 07, 2008
hapndnvegas
  • 35 Answers
SOURCE: How to reset fridge light - Kitchenaid side by side
this may or may not help. Most SMART devices forget their SMART functions when your unplug them and wait a few seconds then plug them back in this should reset it!!
Posted on Apr 13, 2008
catriver
  • 878 Answers
SOURCE: My whirlpool refrigerator trips the main power
Pankaj, Do you have a ohm meter? Sounds like you have something shorting back. First take the meter to the cord. On the end of the cord, you should show no continuity from each male prong to the ground prong on the cord itself. If you show continuity, you have something shorting back. Then I would start with the compressor, Unplug the wires going to the overload and relay, make sure the units unpluged and meter the cord again. If it's ok, then the problem is in the overload and relay. Start there and let me know, if it still showing a short, then we will have to go to the controls, heater, and repeat the process until you find the culprit. Catriver.
Posted on Jun 10, 2008
  • 221 Answers
SOURCE: LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jan 16, 2009
  • 28 Answers
SOURCE: New Kitchenaid refrigerator often makes sharp bang noise.
I have an old Amana bottom freezer that does that. It's because the defrost heaters are doing their job and the area around them as well as the coil is expanding rapidly. Try making certain that the cabinet is level and not on an unsteady footing. You might want to try turning the T stat in the freezer to a lower setting. Usually between 2 1/2 and 3 1/2 works best in all freezers. If none of this helps and the banging continues, get used to it or get another fridge. It seems to be a failing in bottom freezer models for some reason. It's harmless but annoying. I actually know someone who says she has the ghost of a frozen turkey stuck in her freezer that's trying to get out! LOL!
Posted on Jul 09, 2009
Kitchenaid refrigerator control panel
Light switch has gone bad use your model number to order a new one
Jul 25, 2013 | KitchenAid Refrigerators
I have a Kitchenaid refrigerator/freezer and the freezer is not freezing.
Likely your compressor start relay thats bad.
Follow the guide here to check it: How to replace a (Whirlpool/Kenmore Model 106) Refrigerator Start Relay
Just use like a guide, accroding with your right model.
Good luck.
May 05, 2011 | KitchenAid Refrigerators
The freezer is leaking water out the bottom model #ksrg2tfkst18 kitchenaid
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | KitchenAid Refrigerators
Kitchenaid frig model kbfa25erwh. Frig is not working but freezer is ok. Any suggestioms
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | KitchenAid Refrigerators
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Side by side kitchenaid freezer temperature indicator.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 30, 2009 | KitchenAid KBLP36FMS Bottom Freezer...
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
