Question about Evenflo Comfort Select Autocycling Breast Pump Kit
I need a replacement overflow valve for my pump how do I get one?
Freshwater tank fills and overflows even though selector is pointed at 'city water' position.
Other than a leaking 4 way selector valve the probable cause would be a leaking check valve in the pump.
On the RV the city water and discharge from the fresh water pump are tied together. When on city water the discharge of the pump will have city water pressure on it. If the internal check valve on the pump is leaking, water will flow through the pump backwards and into your fresh water tank.
Typically this requires ether replacing the pump or installing a secondary check valve between the fresh water tank and the pump suction.
Oct 28, 2015 | Keystone 2013 Alpine 3720FB
Error code F09 for whirlpool
F09 Overflow condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2e96NFcLn
Sep 06, 2013 | Washing Machines
Need replacement overflow valve, for a comfort select asap, but don't know where to get one from. Is there a method of using the pump without one.
you need to get Comfort select spare parts kit bag - item # 24500301 (contains valve and extra membrane) $1.37 + $5 shipping.
go to
https://plweb.evenflo.com/replacement_parts.aspx
to order.
Jun 25, 2011 | Evenflo Comfort Select Autocycling Breast...
Im switching gas from rear tank to front tank or from front to back and it is causing overflow
sounds like the switching valve for the gas to draw out one tank first then the other tank is bad and needs replacing.this can cause gas to be pumped into the other tank causing it to overflow.
Apr 20, 2011 | Ford F-150 Cars & Trucks
Machine is flashing F09 and it doesn't tumble
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation
Jan 29, 2011 | Whirlpool Washing Machines
Gas overflows when i pump gas in
You need to have the vent valve check at the dealer,it's not letting the fuel go in because of the pressure trying to get out,since the vent valve is not working
Dec 31, 2009 | 2001 Kia Sportage
Water overflowing after i raised the temp, put
Your expansion tank needs to be drained or the mini expansion tank has a hole in the diaphram...pump the mini expansion tank back up with approx 15psi air ....ofetn once the overfolw is activated it doesn't stop...try opening the valve manually and snap it closed again...if it doesn't stop you will need a new relief valve
Oct 28, 2009 | Heating & Cooling
Dishwasher overflows
Sounds like you've got a problem with the water intake valve(s). If it takes on water without water running in the sink, that is where I would look. If it happens when you use the sink, then I would also check your drain hose placement
Jun 22, 2009 | Dishwashers
Kenmore HE3 F 09 error message.
F09 Overload condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check / Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation Replace failed component.
Sep 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Evenflo Comfort Select Autocycling Breast Pump Kit Logo
586 people viewed this question
Top Evenflo Baby Care Experts
gbob59
Tom Chichester
Eileen McGreevy
Eileen McGreevy
Are you an Evenflo Baby Care Expert? Answer questions, earn points and help others
