Question about Poulan Garden
Need a carburetor adjusting wrench - Poulan Garden
  • 297 Answers
Go to BECO.com and you can order one.
Posted on Nov 10, 2010
What is the float adjustment on the carb I know how I just need the measurement on it
Search Results
    Adjusting Carburetor Float Level - YouTube
    ? 2:06
    https://www.youtube.com/watch?v=aiexehn33kg
    Oct 9, 2013 - Uploaded by Mike Nixon
    How to adjust a carburetor's float level. ... Motorcycle Mikuni CV Carburetor Cleaning for Suzuki, Honda, Yamaha Tutorial - Duration: 30:56.
    Motorcycle Carburetors ' Float Height Setting ' Fix.com
    https://www.fix.com/blog/motorcycle-carburetor-float-height-adjustment/
    Oct 17, 2014 - Learn about carburetor parts, how they work, and how to adjust thefloat height to fix your bike from running rich or lean.
Jan 11, 2016 | UM Motorcycles
I have loss of power on my tractor when blade and transmission are engaged. Engine sputters and backfires.
We're assuming that nothing has been done to diagnose your problem. I personally would start by removing the carburetor bowl and check for any contamination of either water or any other form of contaminants. If anything is found clean the carburetor bowl all out. The carburetor bowl I'm referring to sits on the very bottom of the carburetor and normally is held on with a brass colored plug or it will have a fuel shut off solenoid which will have a single wire that can be disconnected. Both styles( plug or solenoid) can be removed with a 1/2 wrench. If it is the electric solenoid style you may have to sacrifice one of your wrenches by grinding it down for there's not much room between the solenoid and the carburetor bowl. Care will have to be taken when reinstalling the bowl for the seal can fall away from where it should sit and can be pinched causing a leak. Start there and if that's not your problem we'll check other common options.
Sep 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a yamaha 1981 pasola scooter and i sometimes starts but sometiimes doesnt. i.bought a ignition coil but it not that. what is the lil blak box that the coil wire connects to? cos thats the problem...
Instructions
  1. Spark Plug and Sensors
    • 1 Park the motorcycle on its center stand. Remove the spark plug-wire cap from the plug by hand. Loosen and remove the spark plug from the cylinder head with a spark plug wrench.
    • 2 Gap the spark plug to 0.026 inches with a spark plug gap gauge. Reinstall the plug tightly in the cylinder head with the plug wrench. Reattach the plug-wire cap by hand.
    • 3 Detach the wire lead at the fuel sensor on the right side of the cylinder head by hand. Loosen and remove the sensor with a metric wrench. Clean the inner end of the sensor with spray cleaner. Reinstall the sensor securely with the wrench. Reattach the wire lead.
    • 4 Detach the wire lead at the exhaust sensor at the underside of the muffler by hand. Loosen and remove the sensor with the metric wrench. Clean the inner end of the sensor with spray cleaner and reinstall the sensor securely. Reattach the wire lead.
    Throttle and Carburetor
    • 5 Take a position where you can observe the throttle linkage at the left side of the carburetor. Twist the throttle grip at the handlebars slowly as you observe the action of the linkage.
    • 6 Tighten the cable adjuster at the top of the carburetor with a metric wrench in small increments so the linkage responds immediately as you open the throttle.
    • 7 Start the engine and allow it to warm up for three minutes. Locate the smaller idle-adjustment screw and the larger fuel-air adjustment screw at the right side of the carburetor. Turn the idle-adjustment screw to the right one full turn with a screwdriver.
    • 8 Turn the fuel-air adjustment screw to the right or left with a screwdriver as you listen to the engine's speed. Turning it too far either way slows the engine's speed. Find the point where the engine idles at the fastest speed.
    • 9 Allow the engine to idle. Turn the idle-adjustment screw to the left one full turn.
Jan 14, 2013 | Motorcycles
1973 chevy c20 carburetor problems
There is are special wrenchs used to remove the line, it is called of all things a line wrench, go figure. Any parts store should have the tools or you can buy it a Sears.
Jun 08, 2017 | Chevrolet Cars & Trucks
When the bike gets warm it idles at stop lights at 3,000 rpms. Usually is idk 1.5k? Is this over heating what do I do?
You may be dealing with a combination of problems. I suspect you may have air leaks possibly in the intake manifolds. This would cause lean running conditions. To compensate for low idle you would have to raise the idle speed. Some fuel system cleaner in the tank and a short drive will help get you ready for the next step. One screw generally will adjust the idle of all four /three /two carburetors at once (depending on the model). If the bike will not run unless the carburetor idle is turned way up, it is probably because the carburetors are out of sync. With the proper equipment basically a set of vacuum gauges , a wrench, and a screw driver , you should be able to adjust the carburetors so they all open at the same time. With any luck stopping the air leaks and tuning up the carburetors should fix your idle/take off dilemma.
Jan 13, 2011 | Suzuki GSX 600 F (Katana Motorcycles
Tecumseh Carburator Adjustments settings
Usually a Tecumseh with these symptoms has a clogged jet somewhere. If you dismantle the carburetor and clean out all of these tiny holes with a wire or something and spray it off with carburetor cleaner and reassemble it, it should work. Turn the adjustment screws in just until they touch the seats counting the turns and reassemble it with them the same number of turns off of the seats. Also, put fresh gas in it if you haven't. Gas being left in them is the main cause of this. If you put Sta-Bil in the gas before putting it away or run it out of gas it should prevent this from happening in the future.
Mar 06, 2010 | Impact 1/2" Cordless Wrench Nikota...
Need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Jan 11, 2009 | Garden
Finding were a filter is
On these vehicles, the fuel filter is located on the fuel line to the carburetor. Special care should be taken when removing and installing the fuel filter, not to bend or distort the fuel line in any way.
  1. Remove gas cap to relieve any pressure that may be present in the fuel system.
  2. Remove the air cleaner bonnet assembly.
  3. Using a backup wrench on the return line fitting on the top of the fuel filter, remove the fuel line with a flare nut wrench.
  4. Using a backup wrench on the fuel filter inlet fitting, remove the fuel line from the fuel filter with a flare nut wrench.
  5. Using a backup wrench on the fuel filter outlet fitting, loosen the fuel line and remove the fuel filter from the engine with a flare nut wrench.
To Install:
  1. Apply a drop of engine oil to all the fuel line nuts and flared ends.
  2. Position the fuel filter with flow arrow on the filter directed towards the fuel line going to the carburetor.
  3. Finger-tighten the fittings at the fuel filter outlet, inlet and return line into the top of the filter.
  4. Using a backup wrench on the fuel filter fittings, tighten the fuel lines in the following sequence:
    1. Tighten the outlet and inlet line nuts to 15-18 ft. lbs. (20.0-24.0 Nm)
    2. Tighten the nut on the return line at the top of the filter to 6-9 ft. lbs. (15-18 Nm).
  5. Inspect the fuel lines and carefully adjust if they are interfering with the carburetor, air pump, or fuel filter housing.
  6. Start the engine and check for fuel leaks at all the connections. Retighten if necessary.
  7. If removed, install the air filter bonnet assembly.
Jul 26, 2008 | 1993 Ford Tempo
Garden Logo
80 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
