Question about Brother Office Equipment & Supplies
I wish to disable the Fax component of my MFC-7340 printer. I no longer use the fax and do not wish to have a fax-tone intercept my incoming telephone calls. There is no information on disabling the fax in the User's Guide, I have an external telephone answering device on the same line and do not want it to be defauilted to two rings, as suggested by the User's Guide.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
How about connecting the land line directly into your'e answering machine.
Posted on Nov 09, 2010
Brothers mfc 7340 when installed the diagonosis said that fax sending was ok but fax receiving said failed.
most probably the quality of the telephone line is poor and the ECM (error Correction Mode) is automatically activate and stops the transmission
Oct 18, 2014 | Brother MFC-7340 All-In-One Laser Printer
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
May 20, 2010 | Brother MFC-7340 All-In-One Laser Printer
When sending a fax I keep getting back a result "BUSY". I've tried a couple different numbers and always get the same thing. Faxes are coming in just fine.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack and not ext jack of the machine, and should go straight to the wall, without splitters or extensions.
If you still cannot send a fax, try another wire or jack
Apr 05, 2010 | Brother MFC-7340 All-In-One Laser Printer
API calls for Brother MFC 7340 Fax/Printer
Probably not. While one exists and has been used by programmers at Brother to create the CCB app etc, they generally do not publish these for small printers. Or large ones, for that matter.
Would be very handy to have one though.
Feb 03, 2010 | Brother MFC-7340 All-In-One Laser Printer
How can i fix the troubleshooting and routine maintenance problem on my brother mfc-7340, i cant receive fax or send.
Plug a phone into the jack and see ifyou have dial tone. if you do then check to see if yo have dial tone when you select hook on the printer. If you do have dial tone then make sure you are pluged in the back in phone not ext. if that is not it then make sure you unit is on fax only.
Jan 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-7420 doesn't receive faxes - send out is OK
If you have the book, go through the setup procedure as if you were installing it for the first time. If you don't have it, go to the Brother website and download it.
Mar 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Fax doesn't recognize incoming phone call
Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
140 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
