Question about Philips SA5125/37 MP3 Player
MY PHILIPS GOGEAR STILL WONT TURN ON!!!!
I tried the volume + method and it still wont turn on. it was working fine not to long ago. once i plug it in the computer it turns on, but thats it. i need help.
  • 8,596 Answers
Uninstall the software that came on the CD, and reinstall the software from www.usasupport.philips.com (Device Manager and PC Software) - then run a repair on the clean version of the Device Manager.
Posted on Jun 17, 2008
Philips gogear 2gb player
all of you are having different issues
1.Reset
2.Run the repair in device manager
3.Run recovery mode: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 07, 2008 | Philips GoGear HDD6330 MP3 Player
Try checking this URL
http://www.usasupport.philips.com/consumer/productDocuments.html?ProductCode=SA1335/37&subCat=FLASH_AUDIO_PLAYERS_SU_US_CONSUMER
check their Frequently Asked Questions and look for the question re power/battery;
This device appears to be dead or no power with nothing on display.
Their last suggestion is to check whether the firmware might be corrupted.You might want to call Phillips as well for the warranty of your player.
Jun 16, 2008 | Philips SA5125/37 MP3 Player
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Cant get mp3 to turn on
Try holding in the volume + button and reconnecting it to your computer. Continue holding the volume + button in until the "found new hardware" wizard comes on. NOTE: if you hold the volume + in for longer than 1 minute and no hardware wizard appears, this strategy will not work with your version of Windows.
Apr 08, 2008 | Philips GoGear HDD075/17 MP3 Player
MY PHILIPS MP3 WONT TURN ON !!!!!!!GRRRRR I NEED HELPPPPPP!!!!PLIZZ
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Apr 04, 2008 | Philips SA5125/37 MP3 Player
My philips mp3 wont turn on unless its plugged into the computer and when i turn it on it says repair and when it says repair now then i hit ok then it says repaired then it shuts down
Good To Go (Gear)!
-Tha Mp3 Doctor
Grrr
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 23, 2008 | Philips SA5125/37 MP3 Player
Philips 1630/17 6gb mp3 player
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Oct 09, 2007 | Philips HDD1630 MP3 Player
My philips mp3 wont work
-Tha Mp3 Doctor
Jun 02, 2007 | Philips HDD1630 MP3 Player
Mp3 wont load fully
-Tha Mp3 Doctor
Oct 06, 2006 | Philips GoGear HDD1850 MP3 Player
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
