Question about Ariens Garden
I have a Ariens mini zoom 1534, model 915069, serial 35005. A spring sheared off, I found it on the lawn during use this past Sun. I got a new spring. The belts now are NOT in tension. I'm assuming this spring is required to put them in constant tension. It is not apparent where to attach the spring. Not sure if I lost another piece, a post or cross bar. I don't have the operators manual. HELP! Leaves are piling up!
  • 376 Answers
SOURCE: Long drive belt cant remember how to put spring back on
The 'j' hook hooks over the transaxle and just hangs there. The spring attaches to the stabilizer rod (reference # 43) and the other end attaches to the "j' hook hanging on the left axle.
Posted on Jun 20, 2009
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
  • 376 Answers
SOURCE: i cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
Posted on Jul 29, 2009
  • 45 Answers
SOURCE: My MTD Yardman HE4160 just stopped yesterday
You can start by getting a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
The above web site also has a "parts finder" that gives detailed drawings for each model.
If you look around under the mower, you should be able to find the hole, or bracket where the spring was hooked. (look for rub marks, or scratches)
If the spring just fell off for no apparent reason, it may have been connected to a bracket that broke off (rust, vibration, etc) It is usually easier to make a new bracket then to try finding a replacement.
Posted on Aug 14, 2009
mowerman1857
  • 389 Answers
SOURCE: Ariens 1534 zero turn mower will not start. It
Sounds like a defective solenoid. Locate the solenoid, using a heavy guage wire or one side of your jumper cables, or just opne of the clamps if you can open them far enough, jump cross the 2 main posts (the ones with the battery cable) and if it cranks like this, replace the solenoid
Posted on Sep 16, 2009
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
Ariens Zoom 34 will not move forward or back
suspect a damaged belt or tensioner spring for the drive belt... these units have no servicable trans-axles. or did you just remove both rear wheels ???
Nov 27, 2013 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Why won't my blades engage on my ariens zoom 1534?
take a look at the wires going to the clutch and make sure the wires where routed the right way and not rubbed against the belt and damage the wires
May 22, 2012 | Ariens 34 In. Zoom Series Riding Mower
Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
Jan 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Hi, i have a Ariens Zoom M 2148 xl tractor model
Probably you can get what you need at a lawn mower shop, they have exploede parts diagrams on microfilm.
Sep 28, 2010 | Ariens 34 In 344 CC Briggs Stratton...
Where can i get an ARIENS drive belt, new or used
Anyplace that sells Ariens mowers will have one. Most other lawn mower stores can also sell you one. Remove the old belt and take that and the model Airens you have to get a replacement. You do not want a used belt just get a new one.
May 01, 2010 | Ariens 34 In. Zoom Series Riding Mower
Ariens 20/48 zero turn left wheel dont want to go.
sealed units factory, take the wheel off see if the key has broke looks like a flywheel key but longer may have sheared stopping the movement of that wheel
Jun 29, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
306 people viewed this question
Top Ariens Garden Experts
Mike
dannydoesita
lnbn1975
Are you an Ariens Garden Expert? Answer questions, earn points and help others
