Question about XO Vision GPS
I have a garmin nuvi 5000. i also have the htc35 backup camera. garmin says i need an a/v cable with white, red, & yellow connectors to a plug that goes to the garmin. i can't find that cable around here but i did find a two connector a/v to the single plug. the htc35 only has two input. power and video. when i hooked it up, the garmin says video connected..when i press yes, i only get a noise fron the garmin. what gives?? do i really need the 3 plug cable. ed
  • 643 Answers
Yes you do yellow is vidieo, red and white are the audio
Posted on Nov 09, 2010
Would like to rewire Astak CM-918 camera due to missing hardware
Red and black, are power; white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Nov 26, 2013 | Astak Home Security
WHERE IS THE BACKUP BATTERY
The CMOS/BIOS Settings backup cell is like the yellow button cell in the 1st pic. It plugs into a tiny white connector shown at position G7 in the 2nd pic. The cell MAY be blue. Usually has one red & one black wire. These are series 600 mobos but may be different from yours. However, my experience with Thinkpads generally gives the
location of the little white plug near the battery connector as in pic 2.
If the mobo is in situ, generally cell is accessible from battery compartment with battery out.Good Luck.
Dec 16, 2012 | IBM Thinkpad 600 System Board Motherboard
Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Jul 05, 2012 | Garmin Fishfinder 90
My garmin nuvi 200w keeps going into mass storage mode when plugged in to charge.as soon as it is plugged in to charge the screen appears that shows the garmin plugged in the computer. and the map...
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
Aug 06, 2011 | Garmin nuvi 200W GPS
What are the red yellow and white cords for i have a xbox
The side with 3 RCA jacks, red, white, and yellow, is for connecting the USB to a composite video cable. The black connects to an S-video cable; you would still use the red and white plugs to carry the audio. At least the older XBox's had composite video outputs; you just need the composite video cable (which you may have as they came with many video devices (VCRs, DVD players, video cameras).)
If you need to connect this Video capture device to another type of output, you will need a converter. Component to composite video would be one option. However, you will have signal loss with any converter.
I hope this helps.
(Composite video cables: yellow carries video, red and white connectors carry the Right and Left audio)
Nov 22, 2010 | Sabrent USB-AVCPT Video Capture
Hi, I'm having a bit of trouble setting up our hard drive and playstation 3 up to the plasma as the cords are yellow, red and white but on the back of the plasma they have red white red blue and green and...
The red whit and yellow connectors are for the Component connectors, your cable is for Composite connection - incompatible one to each other.
Your tv also has that yellow red and white connectors somewhere on it - probably on the side. Plug the cable there and respect the color coding or it will not work.
Sep 26, 2010 | Televison & Video
Can't connect garmin nuvi 660 to PC USB
Your Nuvi should be Off before connecting....
My Nuvi came with a patch cord that connects from Nuvi to laptop
its a usb cord, same usb cord you find for cameras
Your computer should see that a usb cable is connecting
go to.... www.MyGarmin.com and update maps
Mar 24, 2010 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 205W just white screened. I tried to reset it. Nothing is happening.It just stays white. Any suggestions?
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then I suggest a hard reset.
Finally, replace the firmware and system software using webupdate. Your Nuvi should not need to be able to power up for a firmware update to be possible - replacing the firmware should allow it to power up successfully after the update.
I hope that helps.
Mar 15, 2010 | Garmin nuvi 205W GPS Receiver
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Need to watch recording on tv
If your camera has audio vidio cable (just get a cheap one which has a yellow, red and white connector) connectors. simply plug them in the audio vidio out on camera and audio vidio in on TV and thats it.
Let me know what type of connectors you have on your camera?
THanks
Dec 07, 2007 | Sony Handycam CCD-TRV107E Camcorder
GPS Logo
52 people viewed this question
Top XO Vision GPS Experts
Are you a XO Vision GPS Expert? Answer questions, earn points and help others
