Fuse blows when i turn it on.then turns red - Audio Players & Recorders
  • 87 Answers
You have an internal short. If it is a new receiver within 2years you can shop around to get it fixed. If it is older than that it wont be worth the cost of fixing.
-david
Posted on Nov 09, 2010
On a good man air handler aruf61d14aa model we have trouble with low voltage wiring. Already blew one fuse so thinking I have wired it wrong.
Red is power green (or in a goodman might be grey) lands on g which is for your indoor blower white is for heat. Yellow from the tstat( which doesn't land in the air handler ) is for cooling and goes out to the condenser along with the blue which is common. First unhook all your tstat wires. Put red and green together to turn on blower. Turn power on and make sure it's good. Then add white for heat, turn power on and make sure you're good. This will ensure YOUR PROBLEM IS OUTSIDE the air handler. Then ONE WIRE AT A TIME add back your tstat wire, turning power off and on after each wire. First do red. Then do green then do white then do yellow. TURNING POWER OFF EACH TIME. IF AND WHEN THE FUSE BLOWS you will know what part actually blows the fuse. Let me know. It's possible your contactor outside is shorted and blowing the fuse. This will blow the fuse only when you hook the yellow from the tstat up to the wire going outside to condenser. Remember to unhook everything first. Let me know if you need more help.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 30, 2017 | Heating & Cooling
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
A/c compressor keeps blowing fuse
Disconnect The AC compressor clutch, does the fuse still blow.
Oct 21, 2012 | Cars & Trucks
Eng. controller Fuse keeps blowing when I turn the ignition on to start my car
Have you checked your wiring to starter? It sounds like the power wire going to starter has loosened up.That would cause fuse to blow and also the way you described that the car died. Or even check to see that the red wire going to starter hasn't gotten dinged or melted by the exhaust. Anything that would cause it to short out.
Apr 10, 2012 | 1995 Chrysler Concorde
The cd player is not able to save eny thing like radio channals and every time when i start the car engin the cd make auto eject it mean that i have a problem with saving can u help me about this
you must have a digital volt meter and to find this out .
1. remove radio
2. take the volt meter and turn it onto dc voltage
3 take the black test lead and put it on ground for the radio it will be black find in harness on back of radio .
4 take the red test lead and find the yellow wire this is constant power must have 12 volt on wire doesnt matter if the car is running or off this wire is from battery it gives the radio power to save station presets and the clock and return the cd to were it left off from when radio turned off.
if no power at yellow wire go to fuse panel and use your digital voltmeter to check fuses for a blow fuse . take the meter turn it on meter to dc voltage and the take black test lead and find a good ground (clean piece of metal and then the red test lead start touching testing the fuses.
(turn your car ignition switch to run but dont start car) why some circuit in car only power up when you have car ignition on ....)
on the fuse there is the amp rating in the dead center on either side of the rating is the blads of the fuse expose to test the fuse touch the red test lead to the left and see if you get 12 volts. then test the right side of the fuse to see if you get 12 volts if not fuse is blown . do this to all the fuses untile you find a blow fuse you could just pull one fuse at a time untile you find blow fuse. if you do this make sure right amp fuse get back to the right spot in fuse pannel. if not you could have a fire maybe or melt something in car if a circuit fails and goes to blow fuse and fuse is too big and fuse doesnt blow ....
http://www.tintingbyfredjohnson.com
Dec 28, 2010 | LG LAC-M3600R CD Player
My speedometer and tach fuse blows when I hit a bump. the engine light that turns on when I turn on the fuel pump times out normally but then turns back on for the same duration a second time. the security...
most often these problems are solved by mending the wires going in and out of headlight or faring assembly. They can get worn or pinched during service, or bulb replacement etc.
Aug 22, 2009 | 2005 Harley Davidson FLHTCUI Electra Glide...
16 people viewed this question
 Grubhead
Grubhead
