Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
When I connect it to my laptop, only 1 light it it lights and the WD icon takes a long time to appear on the tool bar. When it does appear it is blinking. When I click on it I have two choices: 1) remove it safely or 2) to get properties or information on the device. It does not appear in the list of drives in "My Computer." If I disconnect it from the USB port the computer makes a sound indicating it has been disconnected.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Posted on Nov 10, 2010
Testimonial: "Some of your suggestions I had tried, but the others, I sincerely thank you for the time and information."
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
I think I have a bad earth on my Lunar caravan
Check all ground connections and electrical paths for correct polarity..
Apr 11, 2017 | Cars & Trucks
I have an acer aspire 5742 laptop how do i turn my webcam on
Hi, Webcams are a great way to communicate with friends and family in other places, while still feeling like they're in the room with you. There are many different types of webcams and many different computers to go with them. So, if you happen to be a new Acer Aspire 1 owner, then follow this simple guide, and you'll be sending video of yourself to friends and family in no time Instructions
  1. Access the main menu of your Aspire 1, and click on the "Start" menu at the bottom of the screen
  2. Click on "All Programs" from the list of options, and then select "Acer Arcade Delux."
  3. Choose the "DV Wizard" option once the menu appears. Wait for the program to load.
  4. Select "Acer Crystal Eye Webcam" from the main menu of DV Wizard. Now an image capture screen will appear on your desktop.
  5. Position the Acer so you are framed clearly in the image capture screen. The webcam is built into the computer with the lens at the top of the screen, so you will have to move the entire laptop to find the right angle. Also, adjust the lighting near you for optimum picture quality.
  6. Go to the tool bar in the lower left hand corner of the computer screen to access the functions of the webcam. If you would like to record, highlight the box icon with the red dot in the middle and the word "Record" will appear over it.
  7. Click the "Record" icon to record video with the webcam. You can also choose "Pause" and "Stop" from the same tool bar. To use video messaging, access your online messenger. Whether it's AOL, MSN or any other messenger service, the program will detect the webcam. All you need to do is enable the video messaging by clicking on the webcam box.
Dec 15, 2010 | Computers & Internet
How to connect bluetooth
In the tool bar or the program bar ( start) there is the bluetooth ICON
click on it and bluetooth settingg will appear. open the bluetooth settings and have the other device switched on to pair. use a passkey to accept.
Now you are connected.
Sep 19, 2010 | ASUS K52JrX4 PC Notebook
I just purchased a Sylvania Netbook. Following the Quick Start Guide included in the package, I went to set up a WIFI connection. The first step is to "click the WIFI icon on the lower right side of the...
should work. make sure the radio is on from either the desktop (not the task bar) or the f9 key. You might need to select the router connection and enter the pass key if locked.
Sep 08, 2010 | Sylvania G-Netbook
I have the VL193 monitor attached to my laptop via blue cable, have checked all connections and display options, resolution, etc. The desktop background photo appears on the monitor but no Windows icons or...
connect external monitor and look it works properly or not .if problem persists , then format and reinstall the' operating system' . use licenced OS(operating system) to install . before that verify that all drivers are present or not . if not , then take the back up of the drivers .
Apr 19, 2010 | Princeton Digital VL193 19 in. Flat Panel...
Black screen
yes, its the light. Its called screen bulb. The bulb is burnt, that's why the screen cannot be lighted up.
The solution is to take it for repairs. There is not settings or adjustment required.
Best regards.
Jan 14, 2010 | Dell Inspiron 1525 Laptop
WD Passport Elite 320 - won't install autobackup launcher
I just spoke to WD support...here is how to solve your problem:( I had the same problem and it works great now)
1. Connect your WD ext. drive.
2. Click open Computer.
3. Double click open the WD blue icon.
4. Double click open WD_Windows Tools.
5. Double click open WD drive manager.
6. Double click open the Setup icon for Vista 64 (the other icon
is for x86 windows)
run the setup and it will take care of your problem. enjoy!
Dec 01, 2008 | Western Digital Passport WDXML800UE...
Wireless connection problem with my IBM G40
right click your task bar icon for wireless then click wireless connections if you have a connection showing high light then click connect
if none show then click refresh network list you may need to do this a few times once one shows high light and click connect
when did your sireless stop working
Nov 23, 2008 | IBM ThinkPad T40 2373 Notebook
MacBook wont run from battery
Apple does have a battery recall/fixing procedure on certain macbooks and macbook pros.
The battery of a MacBook or MacBook Pro computer may:
  • Appear to have no charge (zero percent)
  • Be unable to power the computer by itself; the computer might work only when it is connected to the MagSafe power adaptor, which only shows a green LED
  • Appear with a black "X" icon on the menu bar
  1. Shut down, then remove and reinstall the battery. Test for the issue(s) again.
  2. Connect the MagSafe power adaptor (if you haven't already) and see if the behavior continues.
  3. If the issue(s) persist, download and install the Mac OS X 10.4.9 Update.
  4. If the issue(s) persist, Download and install Battery Update 1.2.
If, after installing the Mac OS X 10.4.9 Update and Battery Update 1.2, a black "X" still appears in the menu bar, contact apple by calling 1-800-MY-APPLE (1-800-692-7753)
Dec 06, 2007 | Computers & Internet
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
371 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
