Question about Garden
Sears chainsawm one goes to prim, the other to supply, which side do they go on
    Brigadier General:
  • 4,088 Answers
Just pick a side at first, then try to prime the carburetor. If correct, the bulb will fill with fuel after several pumps. If wrong, the bulb will remain empty. Hope this helps!
Posted on Nov 09, 2010
Primer does;nt work. Engine will not start until manually primed. Tjhen starts on first pull. Do I need a new primer? How do I do this. Engine is a 12H882 from 1996.
-Every small engine that comes with the prim Bold. You need to prim (Press) couple time before start. This is normal and always.
-You say you have to prim before it can start. This is normal.
Your machine is good. No need to replace any thing.
Good luck and enjoy it
Mai
May 18, 2017 | Garden
Cant keep it running i prim it and it starts but have to keep pumping primer for it to stay running.
this must be a seriously clogged up carb or fuel supply , id use a gentle blast of compressed air to b sure the fuel supply line is clear and its pumping gas up to carb then a thorough carb cleaning is in order as well
Feb 27, 2016 | Cub Cadet Garden
What does prim mean
I think I understand Krystal, Prim and Proper was used to describe any Woman that was Perfect in every way, Mary Poppins comes to mind... Prim described Her Regal Bearing and Impeccable Style while Proper described Her Manners, Intelligence & Heart.
Sep 29, 2014 | Computers & Internet
Which is the primly brakes and secondry brake shoes
The primary shoe is the larger of the two. It goes to the rear of the drum. The secondary is the shorter of the two and goes towards the front.
Aug 27, 2011 | Chevrolet Camaro Cars & Trucks
GE Side by Side Refrigerator Not Cooling but Freezer is working
This is a good indication of a failed fan.
The freezer compartment gets first crack at the compressed coolant and a fan distributes some cooled air to the refrigerator side. When the fan fails, the fridge suffers.
Sears parts department has thousands of illustrated breakdowns of many appliances and if yours is one of them, you can see the location of the fan for DIY purposes and often how to access it.
They also have (for listed appliances) the mfr.'s part number and the failed part can often be ordered right from the page on which it is displayed.
Sears Parts Direct
If you can ferret out the part number, you might check listings in your area for Johnstone Supply which supplies trades people with a huge variety of replacement parts and the prices are often 40-60 under dealer prices for the same items and have never turned me away as a non-professional DIY person.
Jul 13, 2010 | GE Refrigerators
Trying to connect Sears Dishwasher model 110733500 Iknow where the water goes in, but can't figure out where the water goes out I see where there is an outlet that might be it but I must be missing a part...
In the space below the door, look on the left side and you will see 2 almost clear drain hoses. One goes to a loop up the side of the dishwasher, the other is tucked into the left frame just for shipping. Gently pull it out and connect to the supplied drain hose then onto the disposer or drain tee.
The installation instructions should show this fairly well.
Hope this helps,
Ken
Oct 16, 2009 | Kenmore Dishwashers
Whrilpool gas dryer lgn2000jqd stops heating half way
u have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
May 12, 2009 | Dryers
Fuel return line ;is it the same size or smaller than feed line
diameter of return is smaller and avaiable at the dealer or model car-airplane shops
Dec 09, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
