Question about Dryers
Indesit is31v not spinning but still producing heat, when turned inside the door manually it sounds like the drum is catching on the back? any suggestions
COXY
  • 76 Answers
SOURCE: how to reassemble door catch of indesit tumble drier
Very difficult to explain with out pictures, the pin should go through the spring it really is a matter of fiddling until you get it right or go back to where you bought it from and ask them how it goes.
Posted on Dec 01, 2007
  • 163 Answers
SOURCE: indesit washer dryer won't heat up in dryer mode
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
  • 44 Answers
SOURCE: no heat in indesit dryer. cycles as normal
Hi
remove back panel and with a mulitmeter check the stats to see if open circuit if so replace and should be back to normal.
regards
Posted on Mar 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
heatman101
  • 43501 Answers
SOURCE: My indesit dryer is IDV65,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 05, 2011
IT IS NOT INDESIT 123. IT IS INDESIT 133
its prob your inner door catch or door striking plate the inner door catch has a bymetal strip inside that looks the door they wear out but if the striking plate is worn on the door it will also stop the inner catch to lock it is better to replaice both at the same time they are not to expensive to buy and easy to fit just turn off the power to machine unplug take the top off and you can get your hand dowm the front where the inner lock is undue the two screws which holds the inner door catch lift out and unplug the lock plug in new one and put back you will see how to replaice the outer door catch best to take the door off and lay flat
Nov 06, 2011 | Indesit W 123 Front Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Hi, my indesit washing machine has stop spinning.I can hear it wanting to spin but the drum does not move. what can be the problem? thanks
This could be a few thing, the brake on, a sensor, door senor, anything unfortunately, produce this "Symptom" You are best to either look around the links below they are DIY, links to help people fix their things. if you cannot, or do not wish to please get a professional, ask for a "Quote" this way you can, make a decision, as to repair or replace.
http://www.devicemanuals.com/company/Indesit-manuals-page6.html
http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.acmehowto.com/howto/appliance/appliance.php
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
Mar 25, 2010 | Indesit W 123 Front Load Washer
Humming sound
If you open the door can you turn the inner drum by hand , if you can is any there any resistance or does it just spin freely
It sounds as if your drive belt has snapped and what you hear is the motor running on its own
If the drum spins freely you will need to take the back off the machine and see what state the drive belt is in
Ps
Is there heat inside the drum when you try to make it work without a load.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No heat in indesit dryer. cycles as normal
Hi
regards
Mar 12, 2009 | Dryers
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Jul 24, 2006 | Indesit W 123 Front Load Washer
Where is the agitator in a Indesit WG1385
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Dryers Logo
89 people viewed this question
Top Dryers Experts
