Question about Zebra Stripe S400 Label Printer
S400 printing poor after changing ribbon. I'm not sure if it printed great before but it had to be better then now. Can calibration help?
  • jimmymaher Jul 01, 2008
    Printer made noise as if something was jammed. We found several labels stuck to one of the rollers and cleaned them off. Now nothing prints, the printhead light is blinking, and there doesn't seem to be any mechanism to allow the labels to feed out from the machine. We can just pull the entire roll out from the front of the printer. Thanks.
  • 197 Answers
Most likely.
Posted on Jun 16, 2008
Printing of canon s400 poor quality on my computer but prrint fine on other computer
under printer driver properties on your computer,under print preferences, check the print quality settings. i.e if the quality is set to draft change to high.
Aug 23, 2011 | Canon S400 InkJet Printer
Zebra S600 not printing..replaced ribbon withe as paper/ribbon light solid..still no print after attempting reprint many times (the printing result are white labels)
Just a thought, Zebra Ribbons are Coated Side Out. Take a piece of tape and press it against the ribbon, ink should come off on the tape.
If not then make sure the ribbon is the correct type and that you have it loaded properly. Also, if you use multiple ribbons i.e. wax, wax resin or resin make sure that you have the correct ribbon for the media installed.
Hope that helps.
mikeo@acebarcode.com
www.acebarcode.com
Aug 21, 2011 | Zebra Stripe S400 Label Printer
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
I changed the ribbon on my IBM Wheelwrite 3 that was printing perfectly only to find that with new ribbons, the letters half-print. The print quality is poor. What could have happened? I have a brand...
Most likely the print solenoid cap is cracked. We sellthem for 20.00 includes shipping and instructionks. If only the top of the letters are printing to be sure the platen id filly seated in the side frames.
DickyO
Jan 16, 2011 | Office Equipment & Supplies
Print quality poor for mp780. Had s800 which
There seems to be a calibration problem. Follow the calibration test from the manual.
If you are using original cartridges, go to canon for repair.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Ribbon not printing correctly on new labels have a sato CL412E and we are using the same ink ribbons we always use (premium wax/resin ribbon TRX-55) and we just started using new labels from a new company...
The ribbon / label combination usually doesn't have anything to do with print position of the fields on the label. Is the quality/durability of the print that you are seeing on the new labels the same as before ? With a glossier stock print quality should actually be better. This will at least tell you that the ribbon is correct for the new label stock. Is the new label a different size than previous labels ? That could account for the fields not printing in the correct position if the printer is not calibrating correctly on the new size.
Not sure if this will help but may give some ideas...
Apr 07, 2010 | SATO Cl412e Label Printer
Need to direct thermal print
Remove the ribbon. Load the direct thermal stock. Power the printer down. Count to five. Return power to the machine and then press the calibrate button (go throught the calibrate sequence). If that does not work. Let me know. There is a way to return to factory defaults and it should sense when you have a ribbon loaded and go to direct mode automatically.
May 26, 2009 | Zebra Stripe S400 Label Printer
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Phaser 6250 black toner is super light
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Click on Knowledge base from this site , then in the search box enter poor black quality. Look under black is faded or missing
Apr 08, 2008 | Xerox Phaser 6250N Printer
Zebra Stripe S400 Label Printer Logo
114 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
