Question about KitchenAid K45SS Classic Stand Mixer
Is the plunger for the meat grinder of the kitchenaid mixer made of plastic and both a wrench for the cap to hold the blade in place as well as a plunger?
4 Suggested Answers
  • 25 Answers
SOURCE: KitchenAid Mixer
depending on the model there is a round cover on the front of the mixer. Detach it to expose the secondary drive connection. Depending on what you are connecting to it you need to connect to the drive port and secure the accessory so it is stable. If you need instructions google kitchen aid and ask them for a manual.
Posted on Mar 26, 2008
SOURCE: Black Residue on meat using Kitchenaid meat grinder attachment
the guy that said that the meat produces this is full of it since the black reside is the blade friction against the round metal piece with the holes, i had black fine powder all over my mixer without any meat
Posted on Jul 19, 2009
SOURCE: I have a Kitchenetics K-11 mixer with a meat
You can buy parts for your machine here:
http://www.mykitchencenter.com/Details.cfm?ProdID=1359
You may have to call them and inquire as to the specific part you need - they also have used parts that they sell.
HTH!
Posted on Aug 21, 2009
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
No i'm only looking for attachments for my kitchenaid mixer model no. ksm90ww
State your country and someone will direct you. What is a batter blade, is that the flat paddle or a dough hook?
Jan 08, 2015 | KitchenAid Food Mixers
Where can I get the service manual for this model?
Hi, Bricklayer.
You can find the parts diagram here: http://www.mendingshed.com/ka6pro.html
And you can order replacement parts there.
How old is your mixer? There was a time that they shipped with a plastic gearbox, and it frequently failed. Kitchenaid went back to all-metal parts after a while.
I have the same issue, but there were no parts - just an attachment drive gear that does not turn.
Mar 22, 2013 | KitchenAid KP2671 Professional 6 Series...
I was using meat grinder attachment and stand mixer stopped running
I just got the same problem too. There was a little piece of fat in the meat and it stopped the grinder. I removed it but the attachment rotates a full turn and then stops. The same happens with other attachments even under practically no load.
Dec 02, 2010 | KitchenAid Food Mixers
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
Put kitcheraid meat grinder back together
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Jan 11, 2009 | KitchenAid Food Mixers
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid sausage maker does not stuff the sausage casings
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
Jun 01, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
154 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
