Question about Maytag Refrigerators
What is the date of mfg for Admiral Refrigerator, Model # ATB1710DRW, Serial # 42711113YM
lojacksdad
  • 121 Answers
SOURCE: admiral side by side refrigerator ,model sal2027gbb
icemaker water valve is bad check to see if you can tell if the unit is turning
Posted on Apr 17, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
57 varieties
  • 1653 Answers
SOURCE: My Whirlpool side-by-side model-ED20ZKXBW00 MFG
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Posted on Nov 10, 2009
walterkunesk
  • 683 Answers
SOURCE: Plug in, lights on, but
is compressor running
Posted on Apr 04, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have acquired an Amana
Hello Tom,
I can not a defintive date based on the data you provided ( mod./ser.&and mfg#'s) but a seach of the parts breakdown tells me it uses R-12 refrigerant so based on that alone its older that 1995 since in 1995 all refrigerators switched to R-134 refrigerant.
For many applince 15 yrs plus they are on their last leg.AMANA was a quility built appliance and just in its infant stage. Just remove the kickplate and clean the coil under it every 6 months it should serve you for many years
Gene
Posted on Aug 20, 2011
I need to know the cubic feet of my Admiral refrigerator model #CNS22V8 serial #KT39003573 Thank you
The details are not available online. Measure it yourself. Measure (in feet to nearest 3") width and multiply by depth, and then multiply that by the height.
1 foot 3" is 1.25
1 Foot 6" is 1.5
1 Foot 9" is 1.75
1.75 x 1.5 x 4 is 10.5 cu ft
May 15, 2016 | Admiral Refrigerators
What is the mfg. date ?
The mfg date or manufacturing date is the day that a product was manufactured.
May 02, 2016 | Optics
(S)EAJM121146
Without knowing the brand looking up models mfg. dates is difficult.
did you check back or bottom for Mfg. date? Usually near the serial number. Sometimes the mfg. date is contained in the serial number. You may also try googling the manufacturers name and view their contact information.
Jul 06, 2014 | Computers & Internet
Cubic feet of 1999 kenmore refrigerator model 70289990
How many cubic feet is my fridge ...Kenmore model # 106.70872990
Serial # EJ4814023
MFG date 11-99
Sep 15, 2013 | Kenmore Refrigerators
My older model kenmore side by side refrig. is not getting the frig or the freezer cold model#9545510 serial #SD4123102 mfg. date 10/94 please help is there something i can try first before getting a...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 17, 2011 | Refrigerators
How do I tell the year an Admiral refrigerator was built?
Most older refrigerators will have the Date Of Manufacture stamped on the model number tag. Most newer models after 1990 will not have the DOM.
If no DOM is present, you can tell if your refrigerator or freezer is made before or after 1995, IF you still have the model number tag. This tag always has the model and serial number, as well as some technical information, including the refrigerant type used in the system. Models made before 1995 will use refrigerant 12, or R12, models 1995 and after will use refrigerant 134A or R134A.
Mar 28, 2010 | Refrigerators
I need to know when my admiral pns24h9 was produced.  It is a 23.6 cubic foot side by side refrigerator.  Any thoughts?
First you will need the Model # & Serial Number off the Tag off the refrigerator.
Admiral was Made by Maytag Corp. now owned by Whirlpool.
This link should help. I would use the Maytag link from this site. This link takes you right to the Maytag Link
Jan 14, 2010 | Refrigerators
I need a copy of the warranty for an Admiral Refrigerator model LAD2615hew
Go to Admiral wbsite and schroll to warranaty info Make sure you have model and serial number ready or just call customer service they will be glad to help,
Dec 17, 2009 | Heating & Cooling
What was the year of manufacture for refrigerator model HMG211747
go to this web site servicematters.com you will need the serial number off of your refrig. this is a maytag and whirlpool site but admiral is made by maytag. remember to use the serial number NOT the model number. thanks Peyton
Mar 12, 2009 | Refrigerators
Refrigerators Logo
88 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
