Question about Acer Aspire 5520-5908 Notebook
AL MOMENTO DE ENCENDER LA LAPTOP ACER 5520 SE PRENDE EL BOTON DE ENCENDIDO Y SE VUELVE APAGAR SE ENCIENDE Y SE VUELVE APAGAR PERO.... EL DISPLAY NO SE VE ABSOLUTAMENTE NADA
4 Suggested Answers
faceofftech
  • 185 Answers
SOURCE: Norcent plasma PT-4235 - Problema: pantalla en
ok here is one question... can hear the windows log-in sound?. If you do what you have to do is have someone or if you can do it, open the laptop and check the cable (flex) that connects the monitor to the motherboard (you have to disassemble) most of the computer or at least the top if you check the cable and is properly connected and still can not see a thing but you can hear windows then the problem is with your video card for that there is two ways to fix it the cheap (not the best) they have to heat the card up with a heat gun (that fixes it for a few weeks) or the other that may cost you a little more (maybe 250??) not sure.
take it to a repair shop and ask if they have a rework station (after they confirm the video card is bad) ask if they can replace the video card ---and don't take it to a big store they won't fix it--- they can unsolder it and install a new one. that is kind of common in some HP laptops.
lo siento hermano espero te sirva mi ayuda if it works don't forget to rate me
thx
Posted on May 25, 2010
  • 273 Answers
SOURCE: MI PORTATIL SONY VAIO PCG FX-120 NO
How old is the battery? Sounds like one of the NIMH cells went dead or the battery management circuit in the battery pack is bad. There are YouTube videos available for laptop battery problems.
Posted on Jan 26, 2011
southexpert
  • 69 Answers
SOURCE: A CABO DE COMPRAR UNA ACER ONE MINI. PRENDE LA
puede hacer la bateria que esta baja, tratar de cargarla primero sacale la batteria luego poner sela y cargar y prenderla de nuevo haver si funciona
Posted on Feb 19, 2011
Sanyo 32 inch blinks off
How many times do this standby light blinks at one time switch ON. Count it. These are fault indications, called blinking codes. From these number of blinks, you can get an idea about the faulty circuit section inside the TV. If you wish to get more details about these blinking codes, http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option. Blinking codes detail to many brand TVs are given in detail.
Jun 24, 2013 | Televison & Video
El auto se apago caminando y ahora no enciende
Es la bomba de gasolina, debes de cambiar el filtro y la bomba, esto puede que pase si es que dejaste el nivel de gasolina muy bajo, puede que no te pase al momento pero si despues, puedes comprovarlo disparando liquido para encender al carburador si enciende es la bomba, otra opcion es que pueda ser la bobina pero de ser esta tu auto debio apagarse totalmente puedes checarla viendo si da chispa metiendo un desarmador en el cable de bujia si da es que si funciona
Feb 09, 2013 | 2003 Dodge Stratus
Plasma Panasonic TH-42PD60X No enciende
BUSCO UNA PANTALLA PARA Panasonic_TH_42PD60X YA QUE LA MIA ESTA ROTA , TODO LO DEMAS FUNCIONA , INCLUSO PRENDE Y SE ESCUCHAN LOS CANALES , O LO VENDERIA ASI PARA REPUESTOS JAIME 320 725 0204 MEDELLIN COLOMBIA.
Jan 21, 2012 | Panasonic Televison & Video
MI PORTATIL SONY VAIO PCG FX-120 NO ENCIENDE.\r\nTENIA UN PROBLEMA EN EL CONECTOR DE CORRIENTE, LUEGO DE SOLDAR FUNCIONO UN TIEMPO Y SE REINICIO. PERO NO CARGA WINDOWS. LO APAGUE TENIENDO SOSTENIDO EL...
Jan 26, 2011 | Sony VAIO FX120 Notebook
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Julio cesar vazquez : tellvaz@yahoo.com
in my monitor the two lines r coming can u explain how to solve
May 13, 2008 | TDV Vison F173 17" Flat Panel LCD Monitor
Acer Aspire 5520-5908 Notebook Logo
298 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
