Question about Zebra P330i Thermal Card Printer
Card is going straight through and into the hopper. No print. If I send the same card through again, it may just have yellow on it. Is this a sensor issue?
    Champion:
  • Zebra Expert
  • 285 Answers
If using Color Ribbon, please send !SA command from the driver. Can solv the provlem.
Posted on Nov 12, 2010
Sticky back card static causing them to stick togeather and not feed from the hopper
Hello Richard,
Sorry for the delay in replying to your request.
Feeding cards (especially self-adhesive types) from the rear hopper, can sometimes be frustrating. You have done the right thing by separating the cards (this applies to all cards - just fan down both sides like a dealer would with a pack of cards). This important.
Please try the following additional trick though;
Remove the rear hopper.
On the front panel, select Menu -> Test Card -> Yes (to confirm).
The rear hopper roller will start to rotate.
Take a fresh cleaning card (from the cleaning kit - 3633-0053) out of its wrapper. It MUST be damp.
Fold it into a loop and manually hold the cleaning card against the hopper roller as it turns (with gentle hand pressure). The idea of folding the cleaning card is to prevent it from being accidentally dragged into the rear of the printer.
After about 12 seconds, an Out of Cards 02:00 error will be displayed. Press Retry.
Turn the card over and repeat until there are no Black marks left of the cleaning card. Repeat as necessary moving to a fresh part of the cleaning card each time.
If the card should accidentally go too far into the printer, a Card Jam 06:05 error will be shown. Just open the lid, and close it again to clear the card jam error. The sequence will carry on from the previous stage (the hopper roller will start turning again shortly after closing the lid).
Once you are happy the roller is thoroughly clean, on the next Out of Cards error, press Cancel.
Discard the cleaning card which will probably have dried out by this point. Replace the rear hopper.
Card feeding should then be trouble-free.
If the problem should persist, contact your local Magicard support centre.
Kind Regards,
MC.
Nov 21, 2013 | Magicard Rio Pro Single Sided Photo ID...
I have a zebra p520i and it will print a one sided card then go into mechanical error, I then can press the select button and it will travel the card past the laminator section and into the exit hopper and...
This sounds like the feed rollers need cleaning. You can use the correct cleaning cards (your dealer should be able to get them for you - but make sure you follow the instructions on the card carefully) or use IPA fluid.on a lint free cloth.
Jun 03, 2011 | Office Equipment & Supplies
P330i - The printer says Ready on the LCD but the computer reads Out of Paper? There are cards ready in the hopper?
please install the driver again, then send the command IM (print testcard)
If not work, Try to send !SA command and then try to print the card.
Oct 08, 2010 | Zebra P330i Thermal Card Printer
Zebra P110 ID card printer card jam on yellow ribbon.
In the driver go to the tools section. In the command to send to the printer box type !SA then choose send the will calibrate all your sensors. As always make sure your clean the printer.
Mar 17, 2010 | Fargo DTC510 Card Printer
I have already printed more than 1000 cards on my printer. Now often it started some problem like it prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as...
I think all you need at this point in time is servicing the card printer, with some of the hardware components like the ribbon been replaced. try get a technician that will help you with this.
I wish you best of luck.
Dec 30, 2009 | Fargo Persona C30 Thermal Card Printer
Card hopper lift erorr
card hopper lift problem the printer is tell me not ready i dont understand it speaches but i can tell you, please can you send the solution for me...... my email address: godfrey_cole111@yahoo.com
Dec 17, 2009 | Fargo DTC550 Thermal Card Printer
It prints the yellow & magenta layers, then skips printing cyan & black (with screeching noise as the ribbon passes) to printing overlay (sometimes skips overlay), but stopped short of ejecting to...
Download the latest copy of the C30 firmware, Fargo created a fix by sending more power to the ribbon sensor. After downloading the new firmware, calibrate the ribbon covering the printer the best you can from light.
Nov 18, 2009 | Fargo Persona C30 Thermal Card Printer
Zebra P240i will not print test card or feed cards
i need the cardfive driver for my zebra P420i card printer.
May 28, 2009 | Zebracard P420I Thermal Card Printer
Resolving a Card not fed error (Cards will not feed off the Hopper)
Make sure that your hopper card thickness guage (located on the right side of the hopper) is set to 30 ml or above if you are using standard 30 ml PVC cards. You may also need to clean the printer with a Fargo printer cleaning kit for this printer.
Also check to make sure to check your PVC cards. Sometimes they have too much static and can stick together not allowing them to feed. Fan the cards before placing them back in the hopper to make sure they are not sticking. In this process, try not to touch the printing surface of the cards as oils from skin will cause defective printing results.
For more id card printer tips, visit our technical assistance blog at www.safecardid.com/blog.
Nov 05, 2008 | Fargo DTC525 ID Card Printer
Zebra P330i Thermal Card Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
