Question about InFocus LP70+ Multimedia Projector
The sides of the display are beginning to get dim or darker
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
The light tunnel is failing or in need of adjustment. Either will need to be done by a tech.
Posted on Nov 09, 2010
MY BESTA CD-168 SCREEN SUDDENLY DIM (BECAME DARKER) AFTER I PUSHED SEVERALY KEY BUTTOMS. DO YOU KNOW HOW TO ADJUST IT BACK TO BRIGHTER SCREEN?
Go into the display options of the operating system and check there first, you can also adjust the monitor if it a standalone type.
Nov 16, 2016 | Computers & Internet
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
ViewSonic VA1926w monitor dims darker when there's dark content on the screen. I have 2 of these monitor connected to a Pro Mac. Only the right side monitor does this.
Its the dynamic contrast ratio (DCR) that dims the display when dark images are displayed.
For my VA1926w, pressing the right most button (up arrow), enables or disables DCR. Keep this disabled.
- Shalabh
Oct 08, 2012 | ViewSonic VA1926w 19-inch Wide LCD Monitor
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
Fx-300ES Calculator will only operate in very bright light. Is this indicating that the battery is not functioning? (Unit is only a few months old).
It is possible that the contrast is set too dim. If that is the case, you can make the display darker.
Press [SHIFT][MODE] to enter (SETUP)
When set up screen is displayed, use the DOWN Arrow to open the second page.
Press [6:<CONT>], then press the right arrow to darken display.
Apr 07, 2010 | Casio fx-300ES Calculator
Can't see LCD on Babylock Esante
When your BabyLock Esante ESi2 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the BabyLock Esante ESi2 LCD screen, or buy a new machine. BabyLock no longer stock this item direct, but there is an affordable replacement available....Check this Link
Feb 28, 2009 | Baby Lock Esante
The sewing advisor screen on a Janome 8000 is getting dim.
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jan 26, 2009 | Janome Memory Craft 9000 Computerized...
Head Lights go dim, instrument panel goes dim when I turn on my Headlights
Does it go completely black or just dim? Most displays dim when you turn the lights on to make the display darker so its not too bright. GPS and other displays do this. Do you have any problems with any other of the car's electronics?
Oct 16, 2008 | 2004 Saturn VUE
The bottom of the screen has become darker!
Hi
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Tv is dim
Ned more info as do all things including the on screen display look darker then normal???how old is set??
Mar 31, 2006 | Mitsubishi VS-70709 TV
InFocus LP70+ Multimedia Projector Logo
63 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
